1992 Accord with bubbles in the dipstick,
i just bought a Accord 92 and wen i was checking the oil the dip stick is had bubbles and i was told that is bad, it also has no power wen on drive you really have to put the pedal to the floor to go..its leaking tranny fluid...is it worth fixing it? the door handle are missing, the engine has oil all over it on the alternator, IS IT WORTH FIXING?
Head gasket needs replaced and your tranny leak could be something small like an output shaft seal or cooler line, but then again, it could be something big like a cracked casing.
Fixing it is up to you, if it were mine and I had no other car, I'd run it into the ground, then take it apart and recycle it. (Recycling often times brings in more money than selling)
MarcosMarcusM
Feb 25, 2009 09:09 PM
MJ23FE
Nov 24, 2002 05:53 PM
Charlie Moua
Jul 26, 2002 04:29 AM
