Headlights info needed.
Old Sep 15, 2008 | 08:07 PM
kojack_0's Avatar
Default Headlights info needed.
Hello H.T before the flaming about the search button, i did search and did not find the answer i needed. I read some of the archived posts and it didnt cover any headlights swaps between years of crxs.
i have an 89 si, and bought a set of headlights from an unknown year [but i know its definitely from a crx]. the reflective shine inside my stock headlight has faded away since its so old. its usdm oem [stanley on the casing, not from ebay or anything]. got it from a friend that has two pairs.
on to my question, before i do a headlight swap. are they the same exact headlights for the years of crx 88, 89, 90, 91? i know the headlight buckets for the ef is different from the crx.
sorry if this question was asked before. i did search and didnt find the answer i wanted.
thank you in advance.
Old Sep 15, 2008 | 08:11 PM
sleepingciv's Avatar
Default Re: Headlights info needed. (kojack_0)
88-89-90-91 crx and civic hatch should be the same the sedan is the differents ones
what ya mean ef is different from the crx??
Old Sep 15, 2008 | 08:21 PM
kojack_0's Avatar
Default Re: Headlights info needed. (sleepingciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepingciv &raquo;</TD></TR><TR><TD CLASS="quote">what ya mean ef is different from the crx??</TD></TR></TABLE>
the crx headlight bucket is different from the ef ones, is what ive read on one of the archived posts.
what im realy asking is if a 90 or 91 crx headlight would bolt up the same on a 89 crx?
Old Sep 15, 2008 | 08:24 PM
ya the 90-91 ef crx or civic hatch will go into your 89 crx only the headlamp will though cause the buckets are differnet from 88-89 then 90-91 cause of the side markers
so all in all you can take the head lamp and put it in your bucket
Old Sep 15, 2008 | 08:27 PM
kojack_0's Avatar
i just confirmed the headlights are from a 90-91 crx.
will that fit into my 89 crx?
it came with the actual headlight and the black bracket that holds it.
the only reason i bought a more fresh pair of headlights is because the reflective shine inside mines are faded away. and i cant see **** at night, plus i already replaced the bulb with brand new 9006 sylvania.
Old Sep 15, 2008 | 08:31 PM
kojack_0's Avatar
i dont know what a 'bucket' is or even know what it looks like.
Old Sep 15, 2008 | 08:37 PM
black bracket= bucket
just put the new headlamps into your black bracket
Old Sep 15, 2008 | 08:42 PM
kojack_0's Avatar
word. good looks.
ill pm if i have questions.
Old Sep 15, 2008 | 08:44 PM
cool there is only like 6 screws ya need to remove to swap them out
start by removing the new headlights from the brackets ya got that way you can learn how to remove them and not mess up yours ok
Old Sep 15, 2008 | 08:55 PM
kojack_0's Avatar
they will align correctly right?
Modified by kojack_0 at 10:04 PM 9/15/2008
Old Sep 15, 2008 | 10:04 PM
aftermath1312's Avatar
i agree wit sleepingciv^^^ crx n hatchbacks have da same headlights.only difference is 88-89 have the conner light dat screw on the side of da fender and 90-91 have corner lights dat only use one screw were da corner light conects wit dat headlight braket...hope u understand wut i mean wit one screw...just look at the corner of da 90 headlight n u will see wut i mean
Old Sep 15, 2008 | 10:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kojack_0 &raquo;</TD></TR><TR><TD CLASS="quote">they will align correctly right?
Modified by kojack_0 at 10:04 PM 9/15/2008</TD></TR></TABLE>ya they will all the screws are in the same spots for the mounting of the headlamps
Ralph Wiggum
May 18, 2006 06:32 PM
B-serious
Mar 11, 2006 09:26 PM
youtouchmytralala
43
Feb 26, 2006 02:04 AM
Vinceg99
Nov 14, 2003 04:20 PM
BuddhaSiR
Dec 4, 2001 01:02 PM
