Aftermarket Crank pulley for CRV........
Does anyone use a Unorthodox Racing Crank pulley for there CRV bottom end? Would the UR crank pulley for an LS be the same as the CRV? or different due to the extra weight of the 84 bore? I'm interested in getting one for my setup let me know what you guys think.
IMO, underdrive crank pulleys are no bueno. Your factory crank pulley, if you notice the back side, has holes drilled where they balance it . The aftermarket ones aren't balanced and could cause a small vibration or wobble, you won't feel it, and in turn wear your bearings faster.
Thanks, J
Thanks, J
It's not even worth the headache to put an aftermarket pulley. Just use the stock pulleys and spend your hard earn money on other stuff.
Do a search on crank pulleys and you will see what I am saying!
-AzianAvenger
-AzianAvenger
iceburgslim
Dec 3, 2001 09:00 PM
