Check engine...knock sensor ????
Old Sep 15, 2008 | 05:43 PM
jdmvtecej2's Avatar
Default Check engine...knock sensor ????
motor is b16 sir2 (B16A) on P30 ECU and check engine came on code says its for knock sensor........BUT it comes on and off and when its on motor redline at 7000rpm?? and vtec comes in at 4500rpms instead of 5 something and then another time it redlines at 6000rpm......????
Is it the knock sensor or the ECU????
Old Sep 15, 2008 | 06:07 PM
geebs's Avatar
Default Re: Check engine...knock sensor ???? (jdmvtecej2)
did you check the wiring for the knock sensor? usually a bad knock sensor..
Old Sep 17, 2008 | 04:01 AM
jdmvtecej2's Avatar
can somebody show me a pic of a knock sensor and also where is it??? is it under the intake manifold???
Old Sep 17, 2008 | 05:42 AM
jdmvtecej2's Avatar
bump
Old Sep 17, 2008 | 07:15 AM
psychotic7's Avatar
it below the IM above the oil pressure sending unit....the connector sticking out of the block should be green
Old Sep 17, 2008 | 07:31 AM
jdmvtecej2's Avatar
Default Re: (psychotic7)
thnkx found it
88 EF Hatch
Engine Management and Tuning
Sep 15, 2009 03:15 PM
sc95delsol
Nov 13, 2007 05:08 PM
t3gb0y420
Jul 2, 2005 01:16 AM
Grnade
May 2, 2005 08:45 PM
