Toda B Cams in C1. Bad or Good with low compression turbo set up?
Old Jul 25, 2002 | 05:04 PM
IMSTOCK's Avatar
Default Toda B Cams in C1. Bad or Good with low compression turbo set up?
ok, so i got my *** cracked this weekend by some crvtec bubbleback. I want revenge. Im pretty sure that if i put some Toda Bs in I'll be out. Problem is i hope to put big boost on my motor in a couple of months. Will I be able to run these cams and a low comp. turbo set up at the same time?
Old Jul 25, 2002 | 06:29 PM
Midwestrider's Avatar
Default Re: Toda B Cams in C1. Bad or Good with low compression turbo set up? (IMSTOCK)
no!!!
those cams are meant for N/A only.
Old Jul 25, 2002 | 06:37 PM
Charles B.'s Avatar
Default Re: Toda B Cams in C1. Bad or Good with low compression turbo set up? (Midwestrider)
keep the intake cam for mad overlap, turbos like that...
Old Jul 25, 2002 | 07:26 PM
slywfbpsi's Avatar
signal auto run the spec b's in their chop top 2 and this guy http://members.tripod.com/turbohonda0/index.html
Old Jul 25, 2002 | 11:43 PM
Charles B.'s Avatar
Default Re: Toda B Cams in C1. Bad or Good with low compression turbo set up? (slywfbpsi)
ttt
lindseyhunt1090
Apr 23, 2016 11:06 PM
spinney
Nov 2, 2005 03:07 PM
EGkid
Jan 4, 2005 07:04 PM
MaD3 In JaPaN
Feb 18, 2002 03:48 PM
SpeedMonkeyRacing
Oct 21, 2001 02:04 PM
