HUGE Garage Sale! EK EG DC-Rota,AC,wiring harness,pumps,lines,lights,pistons,blocks,anything you can
Please put what your buying from me in the comment section of your paypal payment!!
Please note,all items are sold as-is,and there is no refunds.
UPDATED! ALMOST ALL PRICES LOWERED-Ck Out!
List updated,sold items marked and a few new things have been added.
Updated
Ok well the time has come,I have sold my cars,so I am selling pretty much everything i can get pictures of.
Everything is legit and in working condition,i have many good vouches and have sold hundreds of things on here in the past.
If your looking for something in particular and dont see it here just pm me or something i might have it.
All the prices are Not firm,best offers will be taken,so just pm me with offers if you want.
Payments accepted:
Paypal is preferred,however the 3% must be added to cover the fees they take out.
Also money orders and checks are acceptable,and of course cash if you want to pick up something or meet up.Pickups available,just pm me for details.
Here are some of the parts to begin with,i will be adding more as i go along:
Complete Air Conditioning system from a 99 Civic,everything under the hood that you need is included,every hard line,soft line,condensor,fan,compressor,wiring harness,bolts,and brackets.-$325 shipped.
OBD0 VTEC ECU.-SOLD.
JR thermostat.-SOLD.
B18A1 Block,freshly cleaned,and hot-tanked,endcaps and bolts included,as well as various other little items it needs for free.Block is mint condition and sleeves are perfect.Note,the block code has been grinded off,no clue why got it like that.-$100,prefer pickup on this.
B18B1 Block,not clean,very dirty however the sleeves and structure is perfect.The one main web on the inside by the engine code has been grinded out for fitment of a turbo.-$75,prefer pickup on this.
Airbags system from a 94 Integra GSR,comes with complete wiring harness,computer,sensors,and passenger side airbag with cover,black.-$125 shipped.
Both Rear upper seatbelts out of a 00 civic si-$20 shipped.
Energy Suspension Rear Lower BallJoint Boots NIB,for civic or tegs-$7 shipped.
Integra DA(90-93) Cruise Control Unit,uncut with cable and plug-$25 shipped.
Integra DA(90-93) Power Antenna Motor-$10 shipped.
Integra DA(90-93) Both Front Upper Seatbelt assemblies and motors-$45 shipped.
Integra DA(90-93) Rear Upper Folding Trunk Cover,really nice condition,will clean before shipping is the tan color with black underneath-$65 shipped.
Integra DC(94-01) Front OEM Side Power Mirrors,green color paint-$25 shipped.
Integra DC(94-01) Rear Black Taillights Aftermarkets-$25 shipped.
Civic EG(92-95) Front OEM Glass Drivers Side Headlight with brackets-$15 shipped
B16 or Type R AEBS Intake Manifold-80 shipped.
B-series A/C Bracket with ac pulley and adjusting bolts-$25 shipped
Alternators:
3 OBD0 LS Alts-$25 shipped each
1 OBD1 LS Alt-SOLD
1 OBD2 JDM GSR Alt(no pic)-$45 shipped
1 Brand New OBD2 Si Alt(no pic)-$75 shipped
Antenna OEM out of a 99-00 civic si,will fit any other y/m/model as well-$5 shipped.
99-00 Civic Si sway bar bushings,perfect condition-$5 shipped.
B-series rear Energy Suspension Motor Mount Insert-SOLD.
Cats and test pipes:
D-series OBD2 OEM cat,hallowed out w/O2 sensor-$30 shipped.
B-series OBD1 GSR Cat,hallowed out-$30 shipped.
B-series OBD1 GSR Cat,Like Brand new,-$85 shipped.
Custom Test Pipe-$35 shipped.
Downpipe pipe with Flexpipe and 2.5'' flange,new-$55 shipped.
OEM OBD0 LS Distributors w/ caps-$45 shipped each.
JDM Integra DC2 Front Mugen Bumper,Fiberglass,brand new and unpainted-$75 pickup only.
LS Eagle Rods,with probe 9.5-1 comp pistons-SOLD.
Civic EG(92-95) Coupe or Hatch interior parts,Complete center pieces,shifter area and cupholders,the big flat piece under dash,and the center piece off dash with ashtray and coinholders.-SOLD.
Civic EG(92-95) Coupe or Hatch OEM Taillights,inner and outer pieces all with bulbs,connectors and harness' still attached.-$45 shipped.
Civic EG JDM inner taillight parts-$12 shipped.
Civic EK(96-00) Cruise Control Unit uncut with cable and harness plug-$25 shipped.
Civic (96-98)Silver Front OEM HONDA Grill with mesh insert and oem still behind it-$20 shipped.
Civic (99-00) Si front OEM STYLE grill Red-$45 shipped.
Civic (99-00) OEM Front Drivers side Headlight,mint condition w/bulb and plug-$20 shipped.
Civic (99-00) EK9 Type R Headlights-SOLD.
Integra DC(94-01) OEM Mudflaps-$35 shipped.
Integra DC OEM fuel rail with sheath and fuel line-$10 shipped.
Various B-series Flywheels-$55 shipped.
Integra GSR OEM oil pan with -10AN Fitting welded on for installation of turbo return line and a screw on cap for non-turbo apps.-$85 shipped.
Integra LS Oil pan tapped with straight pipe for slide on turbo return line.-$65 shipped.
Integra DA special Edition LS wheels and tires(only 2)with goodyear tires and 7/32 tread left.painted black-$40 for both-prefer pickup.
OBD0 LS auto intake manifold,complete and will come with EGR valve-$35 shipped.
Various Integra LS intake manifolds-$40 shipped(the one complete with injectors,etc is $50 shipped).
Clutch Master Cylinder-SOLD.
Clutch Slave Cylinder.-SOLD.
MSD softtouch rev control 2-step module-$15 shipped.
Civic radiator overflow tanks,oem-$15 shipped each(integra tank SOLD).
Integra 94-01 Power steering hard and soft lines-$15 shipped.
Integra DC2 Vtec oil pumps-BOTH SOLD:
Civic Si 99-00 OEM fuel rail-$10 shipped.
B-series VTEC head cam cap covers-$15 shipped.
Civic 99-00 Si Russell SS Clutch Line brand new-$20 shipped.
Civic 99-00 Si used tie rod ends-BOTH SOLD.
Civic Si 99-00 Motor Mount set,the 2 mounts are filled and hardened with 3m window weld to make them rock hard,complete with all brackets too-SOLD.
Civic Si 99-00 OEM shifter-$10 shipped.
Civic Si 99-00 Federated Drilled and Slotted Rotors front and rear-$95 shipped for all.
OEM Strut bar-$45 shipped.
Throttle Cable-SOLD.
Integra GSR VSS for trans-$35 shipped.
2 VTEC valve covers,one is dirty bad paint and the cam area is cut off-$25 shipped.The other is like brand new,perfect paint and uncut-$55 shipped.
Various motor mounts and brackets,all B-series-PM if your looking for something.
Starters for b-series-$30 shipped each.
ROTA Auto-X 16'' wheels and Tires,like brand new! Come with centercaps,and Spline driver black lug nuts with key.Have brand new BFG G-force Sport tires on them,balanced and ready to go.Tire size is 205/45-16.The wheels are absolutely mint condition and not bent or scratched at all.-$650 prefer pickup.
Wiring Harnesses:
2- OBD1 uncut LS harnesses-$75 shipped for each.
1-OBD0 uncut LS harness-$55 shipped.
1-OBD2 Si front accessory harness wired-$20 shipped.
1-OBD1 GSR Harness uncut-$125 shipped.
1-Battery terminal and starter harness-$15 shipped.
1-OBD1 LS harness w/injector harness cut off-SOLD.
Fuel Injectors:
OBD2 JDM GSR Injectors-$35 shipped
OBD2 Civic Si Injectors-$30 shipped
OBD0 LS injectors-$20 shipped
OBD1 GSR injectors-$45 shipped
Resistor Box-$25 shipped
KD Tools Large Torque Wrench Ft.LBS,works perfect,jsut had snap-on man re-calibrate so it is accurate,comes with carrying case too-$55 shipped.
New B-series Engine Sleeves,company that made them, is NRP(Nippon Racing Performance).They are factory replacement sleeves for the engine block.-$65 shipped(complete set of all 4).
Thats it for now! pm me with any questions,thanks.
I also have numerous b-series sensors,clips for the sensors,a set of front spindles off of a 92-95 civic hatch,and some other things,pm me if your looking for something.
Modified by jsnm at 8:39 PM 10/22/2008
Modified by jsnm at 10:09 PM 10/23/2008
Modified by jsnm at 3:15 PM 10/29/2008
Updated
Payments accepted:
Alternators:
1 OBD1 LS Alt-SOLD
Wiring Harnesses:
Fuel Injectors:
