CRX AC wire harness routing?
Old Sep 15, 2008 | 09:03 AM
Wazup's Avatar
Default CRX AC wire harness routing?
When I got my CRX, the wiring was all over the place, and now I have to clean it up.
I wanted to see if anyone has a pic of where I'm should route the wires for the AC so that they are safe and out the way?
thanks
Old Sep 15, 2008 | 09:59 AM
fireant's Avatar
Default Re: CRX AC wire harness routing? (Wazup)
The AC wiring originates at the evaporator box below the glove box, then goes through a grommet in the firewall, up where one wire splits off to the main fuse box for power, and the rest joins up (taped, but not loomed in) with all the other wiring that goes along the fender to where the battery and passenger's headlights are. The AC relays are attached to the front bulkhead right behind the passenger's headlight. From there, the wiring snakes around the bottom of the regular cooling fan then back up to the AC fan and down to the compressor.
Honestly, that sounded really confusing didnt it?
Old Sep 15, 2008 | 10:28 AM
Wazup's Avatar
Default Re: CRX AC wire harness routing? (fireant)
it did, but i think I can visualize it... a little.
Thanks for the info though.
I should take a pic of how it is right now, everything works, but it looks really ghetto, I just want to clean it up.
Old Sep 16, 2008 | 01:32 PM
xalents23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wazup &raquo;</TD></TR><TR><TD CLASS="quote">When I got my CRX, the wiring was all over the place, and now I have to clean it up.
thanks</TD></TR></TABLE>
Here is a picture if you still need the a/c wiring layout.
HellaStockEJ6
Oct 28, 2013 08:53 PM
boarderfatty
May 15, 2009 05:21 PM
thisiskev
Jul 7, 2008 04:50 PM
fireant
Apr 19, 2008 09:54 PM
(760)doogie
Jan 11, 2008 03:35 PM
