2002 RSX-S Wiring harness
I bought an a2 swap and i am considering just using my a3 ecu, i am going to pull the harness tomorrow..if everything i hear is right (my a3 ecu will work fine kprod)
then i will have no use for the new harness, like i said ill let you know, but most likely will have it for sale.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usmc39273 »</TD></TR><TR><TD CLASS="quote">I bought an a2 swap and i am considering just using my a3 ecu, i am going to pull the harness tomorrow..if everything i hear is right (my a3 ecu will work fine kprod)
then i will have no use for the new harness, like i said ill let you know, but most likely will have it for sale.</TD></TR></TABLE>
The only reason you'd need the harness is for reverse lockout (which you can wire up anyways). I told you the a2 harness was worth a lot.
luvmihatch
Jul 12, 2012 01:14 PM
I got it yesterday, piece of cake.
