How to replace sideview mirrors?
Old Sep 15, 2008 | 06:57 AM
HeirApparent's Avatar
Default How to replace sideview mirrors?
I have a 99 Civic 4D.
I saw this posting on craigslist.
"96-00 civic ek power sideview mirrors(black) $40
96-00 civic ek non-power sideview mirrors(black) $30 "
Not sure which one to get, but my sideview mirror is completely taken off. How do you replace them? I can take a picture of mine if needed.
Old Sep 15, 2008 | 08:19 AM
Apparently this is not easy?
Old Sep 15, 2008 | 08:27 AM
dangthemang's Avatar
Default Re: (HeirApparent)
i'm pretty coupe/hatchback mirrors don't fit a sedan
Old Sep 15, 2008 | 08:31 AM
94EG8's Avatar
Seagull Management
Default Re: (dangthemang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dangthemang &raquo;</TD></TR><TR><TD CLASS="quote">i'm pretty coupe/hatchback mirrors don't fit a sedan</TD></TR></TABLE>
The definately don't on 5th gens, I suspect 6th gens are the same but i've never tried.
Old Sep 15, 2008 | 09:17 AM
Mrmatt3465's Avatar
Default Re: (94EG8)
I'm nor sure on fitment either. In my EG, to remove the old side mirror and put the new one on, you pull off the plastic block plate on the inside of your door, then you take the 3 nuts off. Unplug your harness [if they're powered] and then just pull the mirror off. Once the mirror is off, take of the rubber sealing on the mirror. If the new mirror comes with the studs already in it then you're golden. If not, you have to unscrew the studs from the old one and put them on the new one. Then just replace the rubber seal and put it all back together.
Hope that helps,
Matt
Old Sep 15, 2008 | 11:21 AM
Thanks a lot guys!
Looks like I have to keep searching for an EG mirror. I was hoping the EK would be the same fit. Guess not.
Old Sep 15, 2008 | 12:01 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeirApparent &raquo;</TD></TR><TR><TD CLASS="quote">Thanks a lot guys!
Looks like I have to keep searching for an EG mirror. I was hoping the EK would be the same fit. Guess not.</TD></TR></TABLE>
You have an EK, or at least what is commonly (and incorrectly) refered to as an EK
EG -&gt; 5th gen civic, '92 - '95
EK -&gt; 6th gen civic, '96 - '00
Neither of those definations are technically correct, but these are the generally accepted meanings, what you need are mirrors from a '96 - '00 civic 4 door sedan.
ekillah
Jul 2, 2009 09:58 PM
EJ6_MR
Jan 17, 2007 04:21 AM
iKhmaiFoSho
Apr 5, 2006 06:00 PM
zombie247
Feb 21, 2005 07:40 PM
iriemark
Oct 15, 2002 01:00 PM
