Head Torque Down Specs
I'm putting a D15B VTEC head on a D15B1 block, and i was wondering what do i torque the head to?
What would the redline/HP be for this has MPFI of course.
Modified by Radim at 12:39 AM 9/15/2008
22 ft lbs then 49 ft lbs tighten in sequence , 7200 redline, mpfi does not raise or lower the redline. for that you need a ecu, and internals that can handle say like 9000 redlines
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepingciv »</TD></TR><TR><TD CLASS="quote">22 ft lbs then 49 ft lbs tighten in sequence , 7200 redline, mpfi does not raise or lower the redline. for that you need a ecu, and internals that can handle say like 9000 redlines
Sorry, forgot to add horsepower after redline.
Thanks for the info.
well a stock d15vtec is 130 hp, im not sure if the pistons and rods are the same in the d15b1. i assume the rods are the same, but guessing the pistons are different
BrightRedOne
Oct 24, 2004 09:45 AM
