D16y8 obd0 with PR3 ecu???
So my friend picked up a rex with a d16y8 with obd0 everything,dizzy,wiring,etc.
I noticed the owner was running a PR3 ecu. Isn't that a b16 ecu?
How will that effect the d16y8 performance?
Its throwing 3 codes, One is for a knock sensor,intake air temp,and TPS sensor.
I am going to check on those sensors but i don't think a pr3 should be used in a single cam motor.
What ecu should he use running the d16y8 obd0?
I am in all honesty surprised the car is even running. Y8 timing is all sorts of weird.
Chipped ECU with a specific tune would be your best bet honestly.
si_motor_spt
Mar 21, 2010 07:23 PM
50shotRex
May 1, 2003 08:10 AM
