Stock hatch 94. cold start problem help plz.
Old Sep 14, 2008 | 04:43 PM
hawjboi's Avatar
Default Stock hatch 94. cold start problem help plz.
statistics:
94 hatch.
all i have done to it is dx bottom ex trans, ex y8 intake mani, and accel universal blaster coil. everything used to run fine start up always took like a good 5 sec to finally start up.
now my car wont even start up in the morning BUT, when in the after noon it starts up like it always does. any help guys?
in the morning temp is like 40-60. after noon temp is like 70 ish..
need some help what do you guys think?
Old Sep 14, 2008 | 10:29 PM
hawjboi's Avatar
anyone
Old Sep 19, 2008 | 09:13 AM
foxfai's Avatar
Default Re: (hawjboi)
I have the exact same problem. The car won't start in the morning. It doesn't crank at all. I could hear clicks from the main relay and fuel pump working.
I have a new battery installed few months ago and the connection are checked and they are fine.
I just had my main relay installed by acura due to other fuel issues.
So my guess is that the starter solenoid or something among the line that I should check? Where is that located?
Old Sep 23, 2008 | 10:03 AM
hawjboi's Avatar
Default Re: (foxfai)
when we used to do motor swaps sometimes we get that alot too
when your lights come on are they kinda dim?
if so check your ground wires that could be it for you. happend lots of times when in a hurry
but my situation i changed the timming helped for the first 2 mornings but now its still doing so works durring warm temp.
but i just switch the relay so i got to wait til tormarrow morning to see if it'll start.
Old Sep 23, 2008 | 09:37 PM
dtapia's Avatar
i would check the fuel psi and see if it is bleeding off (ie) bad fuel pump injector and when the system is warm the psi is constant due the the temp out side. ?
Old Sep 24, 2008 | 11:04 AM
hawjboi's Avatar
Default Re: (dtapia)
na i have a gadge for it
thanks for all who helped but i found the problem
a screw in the disributor came loose and craced the rely in side the distibutor
but it still worked
the screw also messed up the rotator metal peice and when warm metal expands thats why when only warm it would start.. and cold no start.. but thanks guys
Dave88LX
Aug 6, 2012 10:03 AM
ranran88ef
Jun 24, 2011 07:18 AM
hawjboi
Sep 14, 2008 04:41 PM
EF9*Hottie
Jul 14, 2008 02:06 PM
angelinaspop
May 12, 2006 11:25 PM
