Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
38mm wheels on a coupe.
Old Sep 14, 2008 | 04:01 PM
hon da top's Avatar
Default 38mm wheels on a coupe.
Does anybody have this offset on their car? Would anyone recommend it?
Old Sep 14, 2008 | 04:39 PM
pd0019's Avatar
Default Re: 38mm wheels on a coupe. (hon da top)
what size? that offset should be good though. may need a little camber but you should be fine.
i've seen people running lower offset, and i am going to be running lower offset and probably -1.5 to -2.0 camber in back and -1.5 in front
Old Sep 15, 2008 | 06:49 AM
Tokyosmash!'s Avatar
Tickle-shits
Community Builder
Community Influencer
Default Re: 38mm wheels on a coupe. (pd0019)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pd0019 &raquo;</TD></TR><TR><TD CLASS="quote">what size? that offset should be good though. may need a little camber but you should be fine.
Nah, 38's will be flush with the fenders
Old Sep 15, 2008 | 06:54 AM
Micha's Avatar
FAILWGN
Default Re: 38mm wheels on a coupe. (Tokyosmash!)
38 to 43 is actually what is recommended by the factory.
Old Sep 15, 2008 | 07:23 AM
a1staecksauce's Avatar
From: Westminster/Huntington Beach/Seal Beach, CA, United States
Default Re: 38mm wheels on a coupe. (Micha)
he hasn't even said what size. andything from 7-9 inch wheel width with a 38 offset will fit.
Old Sep 23, 2008 | 12:24 PM
K5^'s Avatar
K5^
Brand New
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Micha &raquo;</TD></TR><TR><TD CLASS="quote">38 to 43 is actually what is recommended by the factory. </TD></TR></TABLE>
Any documentation from Honda saying that those range of offsets are what is recommended for these cars?
Old Sep 24, 2008 | 01:44 PM
knaira112387's Avatar
what about +35. didnt illfg2 do that?
Old Sep 26, 2008 | 06:08 AM
6spdKEG's Avatar
Default Re: (knaira112387)
bump b/c I want to know what the widest 17" rim can be and fit 235/40/17s Dunlop Direzzas or RT615s on them.
I'd like to get at least a 17x8.5 and not have to fender roll or buy camber kits. roll stock suspension for SCCA autocross.
FYI, just traded in my 06 350Z track model in for a new 08 Si cpe galaxy grey! I think I made a good move!
Old Sep 28, 2008 | 10:38 PM
Socali914's Avatar
I'm gonna get 25mm spacers for the front and 15mm spacers for the rear, im currently running 18x7.5 +50 offset with 235/40/18 tires , reason im running higher in front is cause i have a jdm front which fenders stick out 10mm more. factory is 45mm so 38 will be fine, 7mm isnt that much
Old Sep 28, 2008 | 10:47 PM
pd0019's Avatar
Default Re: (6spdKEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6spdKEG &raquo;</TD></TR><TR><TD CLASS="quote">bump b/c I want to know what the widest 17" rim can be and fit 235/40/17s Dunlop Direzzas or RT615s on them.
I'd like to get at least a 17x8.5 and not have to fender roll or buy camber kits. roll stock suspension for SCCA autocross. </TD></TR></TABLE>
if your on stock suspension i think you'll be fine with a 17x8.5 on 235x40. your only problem may come when your suspension compresses and you might rub a little.
Old Sep 29, 2008 | 05:49 AM
6spdKEG's Avatar
Default Re: (pd0019)
if your on stock suspension i think you'll be fine with a 17x8.5 on 235x40. your only problem may come when your suspension compresses and you might rub a little.</TD></TR></TABLE>
Coo. Thanks for the reply. I might go with a narrower rim. 17x8. More options and less weight.
I am actually thinking of buying the suspension first now before rims. I guess the 06+ Civic Si is in STX which basically will require a Si to run 235s and suspension. I'd rather work out the suspension bugs on shatty tires first. I know tires should basically be your first upgrade but I'd rather put the tires to better use once I have a suspension that can compliment them. i've owned a 95 K20a2 civic race prepped so I know how this road is.. .
Old Sep 29, 2008 | 02:55 PM
K5^'s Avatar
K5^
Brand New
Is there any proof of the offset range of 38-43mm being recommended by Honda?
Old Sep 29, 2008 | 03:03 PM
after I get some money I'm gonna go with 17x9+45. Thats face III for most rim manufacturers and I'll run a 255/40 tire. MugenKid on the ocho is running 17x9+38 or 40 with a 245/45.
Old Sep 29, 2008 | 03:31 PM
FOdoFAsho's Avatar
Default Re: (Socali914)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Socali914 &raquo;</TD></TR><TR><TD CLASS="quote">I'm gonna get 25mm spacers for the front and 15mm spacers for the rear, im currently running 18x7.5 +50 offset with 235/40/18 tires , reason im running higher in front is cause i have a jdm front which fenders stick out 10mm more. factory is 45mm so 38 will be fine, 7mm isnt that much</TD></TR></TABLE>
I thought that JDM fenders were only 5mm wider?
I am running 17x8 +38 and my fronts rub just a little even with the camber set in a tad with the ingalls bolts. I would recommend a 40 series tire..
Old Sep 29, 2008 | 05:54 PM
6spdKEG's Avatar
Default Re: 38mm wheels on a coupe. (a1staecksauce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1staecksauce &raquo;</TD></TR><TR><TD CLASS="quote">after I get some money I'm gonna go with 17x9+45. Thats face III for most rim manufacturers and I'll run a 255/40 tire. MugenKid on the ocho is running 17x9+38 or 40 with a 245/45.</TD></TR></TABLE>
255/40 on 17x9 is going to be counter productive unless you are putting out over 250whp. Tires will on average weigh 4lbs more EACH and wheels around 1.5 - 2lbs depending on offset. Thats adding 6lbs each corner. Not good on a torque challenged Honda when you could get away with smaller.
http://www.tirerack.com/tires/...ocQty=
For a descent price(under $400 per wheel) you can had 17x8 rims weighing in under 17lbs. There are a few under 16lbs as well.
255s fit best on 10" rims FYI
235s are best on 8.5-9s but 8" can pretty square depending on what tire you are using.
* Face 3 is typically not going to be on +45 setups. +40 to +1 to NEG actually
Old Sep 29, 2008 | 05:55 PM
6spdKEG's Avatar
Default Re: (FOdoFAsho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOdoFAsho &raquo;</TD></TR><TR><TD CLASS="quote">
I am running 17x8 +38 and my fronts rub just a little even with the camber set in a tad with the ingalls bolts. I would recommend a 40 series tire.. </TD></TR></TABLE>
What rims and brand/size tires are you running?
Old Sep 29, 2008 | 06:01 PM
FOdoFAsho's Avatar
17x8 +38 RE30's 225/45/17 General Exclaim UHP's
Old Sep 29, 2008 | 09:23 PM
K5^'s Avatar
K5^
Brand New
^Siiick. Wheels are nice and flush!
What made you go with a 45 tire instead of 40?
Old Sep 29, 2008 | 09:48 PM
I've been looking it up. yokohama recomends a 255 on a 9 inch wheel. (I want yokohama advan ao48s). And on with work wheels, volk, gram light and i think another company. 17x9+45 is face III for all of em.
Old Oct 1, 2008 | 06:13 PM
s2kc's's Avatar
[QUOTE=FOdoFAsho]
sex
Low and no vtec
Aug 29, 2013 07:12 PM
WannaRun??
Jul 14, 2012 08:20 PM
8VEYBEYB
Jul 16, 2009 07:21 PM
Fafsa Racing
Nov 30, 2007 06:52 PM
spock_rocker
Feb 6, 2004 03:08 PM
