Greddy evo and ITR b-pipe will it work?
Old Sep 14, 2008 | 01:33 PM
Lro255's Avatar
Default Greddy evo and ITR b-pipe will it work?
I purchase a Greddy evo for a GSR for a super price, and since the b-pipe on a gsr is different can i just use my factory ITR one?
Old Sep 14, 2008 | 03:05 PM
JdMhEaD's Avatar
Default Re: Greddy evo and ITR b-pipe will it work? (Lro255)
It didnt work on my old car...
Old Sep 14, 2008 | 03:08 PM
01-0720's Avatar
Default Re: Greddy evo and ITR b-pipe will it work? (JdMhEaD)
it will physically go on the car, but the flange where the b pipe meets the muffler section is different, oem uses a dount gasket, and greddy uses a flat flange
i guess you could rig it up
Old Sep 14, 2008 | 04:34 PM
Lro255's Avatar
so what you did?
Old Sep 14, 2008 | 04:44 PM
01-0720's Avatar
is that directed at me?
Old Sep 14, 2008 | 04:56 PM
Lro255's Avatar
Default Re: Greddy evo and ITR b-pipe will it work? (01-0720)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 &raquo;</TD></TR><TR><TD CLASS="quote">is that directed at me?</TD></TR></TABLE>
oh sorry, i was actually talking to JdMhEaD
But if you have any ideas please help.
Old Sep 14, 2008 | 05:02 PM
01-0720's Avatar
use the entire greddy system, and get a testpipe or cat from a gsr and youll be fine and it will all fit perfect
the cat on the gsr is a diffenet length thats why the b pipe is a different length
Old Sep 14, 2008 | 05:13 PM
Lro255's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 &raquo;</TD></TR><TR><TD CLASS="quote">use the entire greddy system, and get a testpipe or cat from a gsr and youll be fine and it will all fit perfect
the cat on the gsr is a diffenet length thats why the b pipe is a different length</TD></TR></TABLE>
Actually i did so research and the gsr test pipe doesnt make up for the length of a itr ehaust system.
Old Sep 14, 2008 | 05:18 PM
01-0720's Avatar
get an adjustable omni test pipe
Old Sep 15, 2008 | 04:26 PM
Lro255's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 &raquo;</TD></TR><TR><TD CLASS="quote">get an adjustable omni test pipe</TD></TR></TABLE>
I already purchase a magna flow oem style so that's out of the ?. I just want to know if i get a different o ring or do i need to do welding work?
Old Sep 15, 2008 | 05:16 PM
01-0720's Avatar
no there connections are totally different, to do it right youll need to have it cut and welded
i recomend modding the itr b pipe, theres a small bottle neck right at the rear of the b pipe right by the flange, you can kill two birds with one stone, and cut the pipe off before the bottle neck, and weld on a new pipe with the correct style flange, and fix the bottle neck and be able to bolt on your rear section properlly
Old Sep 15, 2008 | 05:22 PM
Lro255's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 &raquo;</TD></TR><TR><TD CLASS="quote">no there connections are totally different, to do it right youll need to have it cut and welded
i recomend modding the itr b pipe, theres a small bottle neck right at the rear of the b pipe right by the flange, you can kill two birds with one stone, and cut the pipe off before the bottle neck, and weld on a new pipe with the correct style flange, and fix the bottle neck and be able to bolt on your rear section properlly</TD></TR></TABLE>
I guess by cuting the bottle neck help the flow
Old Sep 15, 2008 | 05:28 PM
01-0720's Avatar
nothing crazy but yeah it will help a little
do a search on itr b pipe bottle neck
gsrturboEK
Sep 12, 2008 09:35 PM
jeffk182
Feb 14, 2006 08:26 PM
bgod
Jun 3, 2003 02:44 PM
anhhi
May 24, 2003 10:04 AM
JDM_ITR
May 9, 2002 09:35 AM
