what ecu can i use
Old Sep 14, 2008 | 10:45 AM
1993-eg1's Avatar
Default what ecu can i use
i am building a f22a for turbo i was wondering what ecu can i use because the pob is not chipable
Old Sep 14, 2008 | 12:29 PM
GhostAccord's Avatar
Default Re: what ecu can i use (1993-eg1)
Find yourself a chipable OBD1 ECU from a 92-96 Civic/Integra.
USDM ECU's
PR4 - P06 - P28 - P30 - P61 - P72 - P74 - P75
Modified by GhostAccord at 5:35 PM 9/14/2008
Old Sep 14, 2008 | 11:26 PM
huskyl3oi's Avatar
Default Re: what ecu can i use (GhostAccord)
check phearable they have great deals on chipped ecus. my cousin used them on his lsvtec. id say get a chipped p28 or po6 they might have some basemaps from other people who have gotten there stuff tuned there before.
Old Sep 16, 2008 | 09:28 AM
flight50's Avatar
Default Re: what ecu can i use (huskyl3oi)
if i were you, i'd leave chipping alone. they are preset and it won't be 100% for your car. find you an ecu that can be programmed by a stand alone unit like, hondata,chrome,uberdata, or neptune. also make sure your tuner can use your choice. a turbo build is only as good as its tune. don't skimp out on a chipped ecu. you could loose your investment.
ghostaccord is actually referring to an ecu that can be socketed, in which is what i am referring to. socketed will allow you to use a stand alone.
Nando-tech
Oct 24, 2014 11:01 PM
pnoi_boi68
Jun 24, 2009 12:15 AM
dc2_916
Nov 30, 2008 12:49 PM
tolowhb
Aug 11, 2003 03:27 PM
