not sure what parts to get for d16
Old Sep 13, 2008 | 06:46 PM
JaCkFl's Avatar
Default not sure what parts to get for d16
right now i have a d16 that needs to be rebuilt and am not sure what pistons and rods to get for it. its going to be NA for atleast another year but eventualy want to boost it.
Old Sep 14, 2008 | 07:35 AM
Bisimoto's Avatar
Default Re: not sure what parts to get for d16 (JaCkFl)
You may want to check out our site, or give us a call. You have many options!
Old Sep 14, 2008 | 08:59 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Default Re: not sure what parts to get for d16 (Bisimoto)
If you plan on boosting it, you should run forged internals. Give Bisi a call, he is a God when it comes to single cams.
Old Sep 14, 2008 | 07:57 PM
JaCkFl's Avatar
Default Re: not sure what parts to get for d16 (2LEM1)
checked out the site and it looks out of my price range at the moment . i am looking to spend no more then 500-700 on rods and pistons right now. so i am realy looking for some pistons that i can run NA for not till i get a turbo kit which will be in a year or so. I was looking at eagle and tuner toy rods. are those good choices and why would i chose one rod brand over the other. any info will be much appreciated.
Old Sep 15, 2008 | 10:32 AM
1.5Slowmatic's Avatar
honestly, if your going to turbo eventually, just re-build it as stock and dont waste your money on N/A parts. But, if you plan on staying N/A, you have tons of options for using either OE parts or aftermarket parts. A good OE setup is machined LS rods using PDN GX pistons, as they provide a great CR and have a good design that allows for maximum quench. Stay away from the P29's, as their dome design is less than optimal. Another option would be the PM3 pistons out of the d15B7, although if using on a VTEC motor you would want to clay the motor with VTEC locked to make sure you ahve enough clearance. Than theres teh aftermarket. If you do that get into contact with Bisi about Piston design and valvetrain options
all-mtr-teg
Sep 21, 2009 09:47 PM
ben987
Nov 15, 2008 08:22 AM
redDAinteg
Jun 27, 2005 05:27 PM
BLACK97EX
Oct 6, 2004 06:05 PM
