vss problem after h22 swap....
Old Sep 12, 2008 | 08:11 PM
ram0869's Avatar
Default vss problem after h22 swap....
after swaping my f22b2 engine to an h22 the vss stop working check all wiring, seems ok since it was working before the swap, change the sensor for another one but still not working.. i still need to buy the reverse harness to install the jdm ecu, right now im running a h23 non vtec ecu. could this be the problem? but i dont think this could be it cause everything else works
Old Sep 12, 2008 | 09:34 PM
TheMuffinMan's Avatar
He knows where you live!
What do you mean "stopped working"?
Did the cluster stop reporting the speed? Do you have a CEL for the VSS up there?
You need to post more information (year of the car would help too and the year of the motor)
Old Sep 15, 2008 | 05:33 PM
ram0869's Avatar
Default Re: (TheMuffinMan)
sorry bout that, its a 96 accord lx dropped a 2001 h22a4 5 spd, i drive the car around with an h23 ecu since the preludes its immobilized, but yes before the swap the speedometer was working but after the swap it didnt anymore...
Old Sep 15, 2008 | 05:34 PM
ram0869's Avatar
Default Re: (ram0869)
sorry again, and yes it throws the vss code...
Old Sep 15, 2008 | 05:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ram0869 &raquo;</TD></TR><TR><TD CLASS="quote">sorry again, and yes it throws the vss code... </TD></TR></TABLE>
Need to swap out the VSS
Old Sep 15, 2008 | 05:55 PM
ram0869's Avatar
i did, i swapped the prelude one and installed the accord one which had a few weeks that i had bought it still no working and cell comes on, i read on the faq on the swap to *NOTE: SWITCH WIRES A6 (EGR solenoid) and A11 (H02S heater) at the ECU wonder if this is correct cause i also have a o2 sensor code
Old Sep 15, 2008 | 06:17 PM
Why did you switch the prelude's for the accords?
Old Sep 15, 2008 | 08:34 PM
ram0869's Avatar
to see if it was the sensor that is not working, i tried the preludes and the accord sensor but none give me reading of speed so to my sense it has to do with wiring
Old Sep 16, 2008 | 09:15 AM
flight50's Avatar
your ecu is completely wrong. you can't run a vtec engine properly on a non vtec ecu. now if you had an auto ecu for the h22 then that would work. but sounds like you need to get the correct ecu before you mess something up. vtec has to read the vss and its not doing it with a non-vtec ecu.
Krypto
Jul 14, 2014 01:01 PM
Mr.Honda00
Aug 16, 2011 07:04 AM
Turtle732
Feb 12, 2010 07:39 AM
shavedlude
May 16, 2005 12:44 PM
