Replacing Spark Plugs
Old Jul 25, 2002 | 12:30 PM
wessieball's Avatar
Default Replacing Spark Plugs
I've never replaced spark plugs before. I've got a '97 Civic HX. How do I go about performing the replacement? What gapping should I use? Help...
Old Jul 25, 2002 | 12:34 PM
Spade's Avatar
Default Re: Replacing Spark Plugs (wessieball)
.45 I believe. Don't quote me, I usually look at the manual since it isn't anything I am forced to remember.
Just get a spark plug remover from an auto store.......easiest damn thing to do is change the plugs.
Old Jul 25, 2002 | 12:36 PM
kinesistech's Avatar
Pull out plug wires, remove spark plugs from hole with spark plug socket. Gap is on the hood with valve lash specs, 1.1mm. Install new plugs, plug wire back in. Your done.
Old Jul 25, 2002 | 12:52 PM
brcivic411's Avatar
Default Re: Replacing Spark Plugs (kinesistech)
make sure you mark which wires go with which plug
only change when the engine is cool
don't over torque the plug
make sure no dirt falls into the cylinder
don't pull the spark wire by the wire
uhm... that's all i can think of
Old Jul 25, 2002 | 12:59 PM
BryanS's Avatar
New User
Default Re: Replacing Spark Plugs (brcivic411)
I always just change one plug at a time so I don't have 4 losse plug wires and no idea where they go. This is pretty much what I do.
I buy a set of 4 new plugs,
gap them all with feeler gauges or a plug gapping tool to the specs on the sticker under the hood,
when the engine is cool I remove one of the plug wires from the plug by pulling on the rubber boot around the plug,
I use a deep socket or spark plug socket to remove the old plug,
put a bit of antisieze compound on the threads of the new plug,
I put the new plug in, using enough force to get it snug but not overly tightened (it's going into aluminum , and you MAY want to change them again in the future) - for my prelude the torque specs are 13 lb/ft, which seems to be about 1/2 a turn after it seats by hand tighening,
I then replace the plug wire for that plug and do the next plug in the same manner.
Old Jul 25, 2002 | 01:22 PM
DarkSubRosa's Avatar
Default Re: Replacing Spark Plugs (BryanS)
also maybe put a little anti-seize on the threads of the spark plugs.
Old Jul 25, 2002 | 01:45 PM
Mikey3000's Avatar
how can y'all confuse which wire goes where? it's obvious where they go because of their length.
Old Jul 25, 2002 | 03:21 PM
SEVENSIX's Avatar
Default Re: Replacing Spark Plugs (Salvatore Leone)
Funny thing about anti-sieze, I was pulling my plugs out yesterday and one had so much anti-sieze on it, it was crumbling down into the head!!! Honda had put these in last, they must have used an entire tube of that sheit!!! Kinda pissed me off..
Anyhow, I plugged in BOSCH Plat+4's into it. Pre-gapped and ready to go!!!
Old Jul 25, 2002 | 03:24 PM
Spade's Avatar
Aftermarket ones don't nessesarly come in the correct lengh.
Old Jul 25, 2002 | 03:57 PM
Default Re: Replacing Spark Plugs (SEVENSIX)
ouch, thats why i said a little anti seize, lol..... you can get NGK's pre-gapped too
Old Jul 25, 2002 | 06:16 PM
whatVTEC's Avatar
buy the factory NGK plugs from honda, they don't have to be gapped. but it's good to check anyways
Old Jul 25, 2002 | 09:06 PM
wessieball's Avatar
Default Re: Replacing Spark Plugs (whatVTEC)
Thanks guys. I appreciate the help!!
Lithel
Dec 9, 2008 09:09 AM
eseries07
Honda Civic (2001 - 2005)
Oct 26, 2006 11:28 AM
mickey513
Jul 23, 2004 05:38 PM
ptran
Jun 17, 2004 06:33 PM
Zulu888
Sep 2, 2002 10:16 AM
