JE high compression pistons w/forged rods fs/ft
I have a set of 81mm JE high compression pistons with forged rods for sale. The pistons would yield a 12.4:1 CR. They came out of a GSR motor.
One piston is no good and one rod had a spun bearing. The whole setup has barely any miles on them.
I'm willing to trade for ARP head studs, aftermarket clutch and flywheel or sell them before they were taken out. The pistons cost around $500 brand new. I'm including rods! I'm looking for around $300 obo
Here are some pictures. The rod bolts are not included.
Everything that you will be getting, except for the rod bolts.
Piston 1
Piston 2
Piston 3
This is the piston that needs to be replaced. you can see damage to the top and bottom of the piston pictured here.
Piston 4
Spun a bearing on piston 4's rod
Dome
JE on the underside of the piston
Modified by SL0-hatch at 9:04 AM 9/15/2008
Piston 1
Piston 2
Piston 3
Piston 4
Dome
bigbpatel
Nov 8, 2012 01:56 PM
spoon23_JDizM AkA SpOoN20
Sep 27, 2004 07:48 PM
