Code 16 : fuel injectors
Old Sep 12, 2008 | 09:48 AM
CCCP-ef's Avatar
Default Code 16 : fuel injectors
i resoldered the main relay, changed out the injectors, and changed out the resistor box hoping that would fix it, but its still throwin a code for fuel injectors... anyone have any ideas on what it could be?
Old Sep 12, 2008 | 10:43 AM
Coltmorris's Avatar
Default Re: Code 16 : fuel injectors (CCCP-ef)
I have this exact problem. Check the wires at your dizzy. (ie signal wires, crank pos sensor ect.) Are they properly shielded? Interference could perhaps cause a break in the signal which would then throw the code, if im not mistaken. I will be doing this soon, Ill post my results.
Old Sep 12, 2008 | 01:22 PM
HaulingAddison's Avatar
Have you reset the ECU? I think that could be a hard code that won't go away, even if you replace everything in that system. Pull the ECU fuse and disconnect the negitive side of the battery. Then, go inside your car and hold the key in the start position with the clutch in for about 30 seconds. Then reconnect the battery and put the ECU fuse back in. Check the codes again to see if the code goes away.
Old Sep 13, 2008 | 05:23 AM
Coltmorris's Avatar
Default Re: Code 16 : fuel injectors (Coltmorris)
Oh wait so..the car is running fine? If so, yes reset the ecu
Old Sep 13, 2008 | 06:11 AM
scottmog's Avatar
hey CCCP ti govoriw rysski?
jdmhonDAftw
Jun 7, 2008 10:16 PM
tissimo
Jan 5, 2006 10:15 PM
crxforum
Jun 12, 2004 06:07 PM
allm0torGSR
Apr 30, 2004 05:10 PM
delux247
Jan 28, 2004 11:48 AM
