What are these sensors on the back of the block?
Old Sep 12, 2008 | 09:41 AM
da.nizzle's Avatar
Default What are these sensors on the back of the block?
These are the sensors on the back of the block of my b18a1.
I'm going b20b and there's no spot for the old sensors.
Can anyone tell me what these sensors on the b18a1 are? and what do I do about them on the b20b?
B18a1...
B20b
Old Sep 12, 2008 | 12:58 PM
LA_HONDAS's Avatar
Default Re: What are these sensors on the back of the block? (da.nizzle)
thats a obd0 fan switch
on the b20 it should be on t-stat housing
Old Sep 12, 2008 | 01:11 PM
LA_HONDAS's Avatar
Default Re: What are these sensors on the back of the block? (LA_HONDAS)
and the sensor with the green plug on it you don't need it
you can cut it off and use the plug on the b20 fan switch just take the two wires that hook up to the b18a fan switch and add about a 8" long wire and hook it up to the green plug and hook it up to the b20 fan switch on the t-stat housing
note: the two wires are just grounds you could hook them up anyway you want
Old Sep 12, 2008 | 05:43 PM
da.nizzle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LA_HONDAS &raquo;</TD></TR><TR><TD CLASS="quote">and the sensor with the green plug on it you don't need it
note: the two wires are just grounds you could hook them up anyway you want</TD></TR></TABLE>
Okay gotcha. So the green plug on the b20 is on the thermostat housing and just needs to be extended. Got it.
I just looked it up and the one beside the filter is the oil pressure switch so that's cleared up.
Now what about the one in the first picture circled that has the 2 prongs sticking out what is that for?
Modified by da.nizzle at 6:51 PM 9/12/2008
Old Sep 12, 2008 | 05:48 PM
LA_HONDAS's Avatar
yup thats it
Old Sep 12, 2008 | 06:04 PM
LA_HONDAS's Avatar
the sensor w/ the 2 prongs is the fan switch
Jay Jackson
Sep 16, 2013 11:12 PM
BeniRacing
Jun 30, 2007 06:40 PM
Sirfallsalot243
Dec 22, 2006 08:37 PM
gburly
Mar 15, 2006 05:18 PM
marc-111
Feb 21, 2006 01:12 AM
