Pic request and OPM question CRX differential
Does anyone have a picture of a stock 1st gen CRX differential? Searching on here and google led to nothing.
Also, does the OPM LSD use the stock differential housing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina »</TD></TR><TR><TD CLASS="quote">Does anyone have a picture of a stock 1st gen CRX differential? Searching on here and google led to nothing.
Also, does the OPM LSD use the stock differential housing?</TD></TR></TABLE>
Over at http://www.redpepperracing.com they have the entire Factory Service Manual available for viewing, I am sure there is a diagram of the stock diff.
All LSD's use the stock transmission housing, some require some internal modifications to the tranny case. My Mugen LSD would not go into my 1st Gen CRX tranny without some modification to the inside of the case.
Call OPM and ask any specific questions you may have about your unit.
Scott
Scott
There is not a good view of the diff in the manual, only shows the top side of it. I know it uses the stock trans and clutch housing, I meant does it use the stock differential housing (the diff itself).
HamiltonRex
Feb 11, 2005 10:38 PM
