Difference between 88 and 89-91 harness
Old Sep 11, 2008 | 02:17 PM
GI8U2racing's Avatar
Default Difference between 88 and 89-91 harness
I have a '88 CRX HF with a torn and cut-up main harness. I went to my local junkyard, and they have a '90 CRX Si with a good looking harness. I heard the connector on the driver's side (maybe where it connects to the instruments) is different. I have a '90 EDM VTEC CRX cluster though. What all is needed to use the '90 junkyard harness?
Honda Automotive Parts wants $452 for a new one, that's too much.
Old Sep 11, 2008 | 02:27 PM
89hatcher's Avatar
i think its the same with the si harness.
Old Sep 11, 2008 | 03:47 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: Difference between 88 and 89-91 harness (GI8U2racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GI8U2racing &raquo;</TD></TR><TR><TD CLASS="quote"> I have a '90 EDM VTEC CRX cluster though. What all is needed to use the '90 junkyard harness?
As far as the VT cluster goes....find a 90-91 usdm Si cluster, and take out the 3 main gauges from the screws behind (tach, speedo, fuel/temp)
Do the same with the edm cluster and swap housings. The wire print panel on the back is what is different, after swapping the gauges (15 mins work), the cluster will be plug and play. I love mine
Old Sep 11, 2008 | 06:15 PM
Default Re: Difference between 88 and 89-91 harness (Deetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">As far as the VT cluster goes....find a 90-91 usdm Si cluster, and take out the 3 main gauges from the screws behind (tach, speedo, fuel/temp)
Do the same with the edm cluster and swap housings. The wire print panel on the back is what is different, after swapping the gauges (15 mins work), the cluster will be plug and play. I love mine </TD></TR></TABLE>
What about the 88 connector being different? Does that even matter? Or are both being replaced?
Old Sep 13, 2008 | 11:44 AM
Anyone know?
Old Sep 13, 2008 | 03:03 PM
Deetz's Avatar
Crazy Honda Guy
^^ Its a matter of matching the color of the wires in your case.
Old Sep 20, 2008 | 03:17 PM
FOMULA91's Avatar
I had an 89 HF and try using the 90 Si harness and the only difference I found out was that the 90 SI did not come with the 2 pin fan switch (the one near the oil filter). The 90 Si harness also had a extra plug that goes behind the intake manifold for an extra sensor (don't really know what sensor it was for).
waspcrx19
Jun 24, 2010 05:33 PM
waspcrx19
Jun 22, 2010 09:29 AM
dkrex001
Sep 26, 2007 04:12 PM
crxma22
Aug 16, 2006 11:35 AM
Suck my DX
Aug 25, 2005 08:42 AM
