timing belt adjustment ?
Old Sep 11, 2008 | 06:49 AM
hondachris1994's Avatar
Default timing belt adjustment ?
I got the timing marks lined up then I tightened the tensioner pulley and rotated the motor over twice, then rechecked marks, which everything came out good. Now the haynes manual im using says " 2 properly tension the timingbelt loosen the tensioner bolt 1/2 turn(180 degrees), rotate the crankshaft counterclockwise until the camshaft pulley is 3 teeth past TDC and tighten the tensioner bolt''.... can someone explain the concept of that, cause once I turn the crankshaft 2 where the cams even start moving the belt tightens anyways rather I go 1 teeth or ten teeth. I just wanna get it tensioned rt, so any help is appreciated
jaxflex
Feb 24, 2016 02:17 PM
bigizsosexy
May 21, 2008 03:13 PM
spooncivic1
Oct 4, 2004 06:03 PM
Shady Hills
Jul 24, 2004 09:40 PM
baonest1
Jun 10, 2003 04:03 PM
