dpfi to mpfi swap ?
Old Sep 10, 2008 | 06:10 PM
hondapimp125's Avatar
Default dpfi to mpfi swap ?
ok im in the middle of doin the dpfi to mpfi swap in my 91 std hatchback. ive read and printed the faq out already and ive found a diff in mine to the print out. ok when your swapping ecu's it says b10 and b12 should b empty well mine has b10 empty but b12 is occupied what should i do??
Old Sep 10, 2008 | 08:20 PM
Default Re: dpfi to mpfi swap ? (hondapimp125)
bumpppp
plzzzzz helppp!!!!!!!
Old Sep 10, 2008 | 09:40 PM
julioboostamante's Avatar
b12 sometimes has a wire in it. if so your fine! just one less wire to pin in that spot. cut it and run it to where the instructions say to.
c1 & c2 are cam angle and if i remember right b10 and b12 are crank.
Old Sep 11, 2008 | 02:54 AM
Default Re: dpfi to mpfi swap ? (julioboostamante)
ok thank you.
its extremely appreciated !!!
Old Sep 11, 2008 | 08:34 AM
b18integraboy's Avatar
when we were doing the swap we noticed this thing bolted up to the driver side of the intake manifold in the back, its not the iacv but there is nothing on the DX harness to plug into this thing
bradennicely
May 14, 2010 02:34 PM
2fast4udude
May 14, 2006 10:24 AM
acuratech
Jun 26, 2003 11:05 PM
88EF
Sep 14, 2002 02:45 PM
