2- H22A4 MOTORS 1 Blown Swap - 1 Complete Long Block - 97' Prelude Part Out - 310 AREA!!
<FONT SIZE="5">NEW LOWER PRICES FOR EVERY ITEM!!!</FONT>
ALL PARTS ARE FOR PICK UP ONLY!!! NO SHIPPING!!!
2000 H22A4 Base Model Complete Long Block ***PERFECT WORKING ENGINE*** -
<FONT SIZE="5">$750 NEW LOWER PRICE!!! NEED THIS GONE!!! COMES WITH BOTH OBDI AND OBDII PARTS!!!!!</FONT>
Complete from Valve Cover to Oil Pan-
-Has under 80,000 miles
Comes with Complete intake manifold, Clutch and Flywheel, Aluminum Flywheel Cover, etc.
Previous owner did recent maintenance on timing belt and water pump. Also did the manual tensioner upgrade.
Selling because I bought this motor to swap into my cousin's Prelude SH that had a blown motor, not knowing that there are two different types of blocks (Base and SH). I haven't used this motor. Bought from user "DCFIVER" here on h-t. I have the receipt for this motor. Selling it for what I bought it for. http://www.hondamarketplace.com/zerothread?id=2357030
1998 Prelude SH Complete Swap ***Blown Engine*** Part Out (All Parts for sale!) Make Offers!!!
- Engine came out of my little cousin's prelude. He was driving without any oil and the motor went bye bye. It still turns over. Never taken apart. Under 150,000 miles.
- Complete Long Block (I/M, Header, Dizzy, Complete from Valvecover to Oil Pan) - $500 for complete ENGINE AND TRANSMISSION - NEW LOWER PRICE!!!
- Has low compression in #1, #3 cylinders.
- Transmission has slight grind in 3rd gear. - NEW LOWER PRICE!!! $250
- OBDII Complete Wire Harness (UNCUT) - $100
- A/C Compressor - $50
- Alternator- $50
- Starter (OBDI) - $50
--1997 Crashed Prelude SH--
Car has been junked! Only the parts listed are available!!!
- I bought this car off of another h-t member for the motor.
-Rear Bumper $50
-Radiator w/Fans - $50
-Misc. Interior Pieces - Make Offers
-Misc. Motor Mounts/Brackets - Make Offers
-OEM Plastic Undertray - $25
<IMG SRC="http://img.photob
- Alternator- $50
-Rear Bumper $50
thanks for your opinion. are you planning on purchasing if it was lower? how much should a blown bottom end be worth? or a complete top end?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkim48 »</TD></TR><TR><TD CLASS="quote">thanks for your opinion. are you planning on purchasing if it was lower? how much should a blown bottom end be worth? or a complete top end?
i was.
blown motors that you didnt blow= anything could be up in there. valves embedded into piston with a cracked sleeve. you ust don't know.
blown motors aren't worth much
</TD></TR></TABLE>i was.
damn cousin's car doesn't start again...i hate [freak]in preludes!
