Please help me identify that the right ECU is in my car **PICS**
Old Sep 10, 2008 | 04:19 PM
BumperLT's Avatar
Default Please help me identify that the right ECU is in my car **PICS**
1992 CX w/ D15b vtec
I searched for about 30 min before posting
I bought the car last week and its have a few small problems so I want to make sure its the right ecu for the right application. There are two wires changed at the ECU, both orange, on with silver on it, and one with blue (i think). I dont know much more than that without looking. The ECU has NO sticker on the outside. I opened it up and again found no markings to indicate what it was, based on the connector set up, it is an OBD1. I snapped a couple pictures:
It is a P05 ecu that I need right? Is there a better choice for a 92 CX w/ a D15B?
Old Sep 10, 2008 | 06:11 PM
Tomdata's Avatar
Default Re: Please help me identify that the right ECU is in my car **PICS** (BumperLT)
The ecu you have shown in the picture is a "chipped" OBD1 VTEC ecu. I cannot tell what model it is but if I had to guess I would say its probably a P75 with a vtec conversion. That ecu should work fine with your setup as long as the "chip" that was put in there has the correct program on it for your engine.
Old Sep 10, 2008 | 07:13 PM
BumperLT's Avatar
I was going to ask something about it being chipped or not because i found out today it will not go past 3500 rpms when the clutch is in.. it just bounces there. Is there anything else you can tell me about it by the pictures? How can you tell that its chipped and vtec? I'm sure that you know which chip it is, but I dont?
Old Sep 10, 2008 | 07:30 PM
zccr-xsi's Avatar
Default Re: Please help me identify that the right ECU is in my car **PICS** (Tomdata)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tomdata &raquo;</TD></TR><TR><TD CLASS="quote">The ecu you have shown in the picture is a "chipped" OBD1 VTEC ecu. I cannot tell what model it is but if I had to guess I would say its probably a P75 with a vtec conversion. That ecu should work fine with your setup as long as the "chip" that was put in there has the correct program on it for your engine.</TD></TR></TABLE>
Old Sep 11, 2008 | 02:49 AM
ch0g0nda's Avatar
Default Re: (BumperLT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BumperLT &raquo;</TD></TR><TR><TD CLASS="quote">I was going to ask something about it being chipped or not because i found out today it will not go past 3500 rpms when the clutch is in.. it just bounces there. Is there anything else you can tell me about it by the pictures? How can you tell that its chipped and vtec? I'm sure that you know which chip it is, but I dont?</TD></TR></TABLE> Launch control.
Keeps the engine at a predetermined rev limit while the clutch is in.
Old Sep 11, 2008 | 04:21 AM
zccr-xsi's Avatar
Default Re: (ch0g0nda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ch0g0nda &raquo;</TD></TR><TR><TD CLASS="quote"> Launch control.
Keeps the engine at a predetermined rev limit while the clutch is in.</TD></TR></TABLE>
CLOSE!!
it work with your vss,your ecu read the singal wire coming from the vss when it see its not moving at a dead stop or under like 5 mph it wnt rev past a certin rpm u set till your car starts rolling then l/c will disengage.
is your ecu showing any codes?cause if it is that 3500 rev limiter could be limp mode.
Old Sep 11, 2008 | 06:27 AM
BumperLT's Avatar
No, the CEL is not on. I did make sure it works by turning the key on to on and made sure it came on briefly.. which it did
Old Sep 11, 2008 | 06:43 AM
zccr-xsi's Avatar
go try to run it and see what happens.frist when u start it let it warm up some before u drive it and let it warm up fully (let the fan kick on) before make a hard run.im wondering if they set the cel shift light.
Old Sep 11, 2008 | 09:50 AM
BumperLT's Avatar
i get on it pretty often when its warmed up and the cel has never come on.
J_Barajas
Aug 19, 2017 12:21 PM
Tong.Y
Nov 12, 2010 05:09 PM
Wytek9
Engine Management and Tuning
Apr 19, 2009 02:38 PM
crxstylin
Free Stuff
Mar 29, 2009 11:03 PM
hung_kuen
12
Nov 20, 2007 08:26 PM
