Question regarding strut bar install on 00 civic?
Old Sep 10, 2008 | 04:03 PM
ic3pham's Avatar
Default Question regarding strut bar install on 00 civic?
Will these strut bar fit on my 2000 civic ex coupe and how do you install them? Do I need proffesional installation? THanks alot for your answer. I really appreciate it.
http://cgi.ebay.com/ebaymotors...17640
Old Sep 10, 2008 | 04:35 PM
mrlegoman's Avatar
Default Re: Question regarding strut bar install on 00 civic? (ic3pham)
You need a wrench and about 3 minutes of time to install the front and rears. Very easy install.
Front and rear ties will require jacking up your car. Be sure to use jack stands and not get yourself killed by the car falling on you. Other then that, they are also an easy install.
Old Sep 10, 2008 | 04:50 PM
blkegcoupe's Avatar
From: ....................................................................................................
where do the tie bars bolt up to? and is it better than a sway bar and can you use it with a sway bar?
Old Sep 10, 2008 | 04:56 PM
unsungfate's Avatar
Default Re: (blkegcoupe)
yes you can use them with sway bars. hell no they are not better than a set of sway bars.
Old Sep 10, 2008 | 05:12 PM
alphalanos's Avatar
Default Re: (unsungfate)
when you install strut bracing its better to have the car off the ground when you tighten it so that it maintains the shape of the chassis better when the car is set down.
Old Sep 10, 2008 | 08:28 PM
ic3pham's Avatar
Default Re: (alphalanos)
THanks alot guys. Do you guys recomend those strut bar or is there something else that is better. How about those H braces ? are those any good?
Mr.Death
34
Jun 30, 2013 03:51 PM
court
Jan 29, 2009 05:52 PM
olookitsamoose
Aug 2, 2005 11:50 PM
Uneekpinoysk8er
Sep 30, 2003 04:08 PM
k.
12
Jan 9, 2003 10:36 AM
