are there different throttle postion sensors for hondas??
it seems like all 88 to 2001 tps are the same and the little nipple is in the same postion on the tps are there any different ones??
dpfi are the only different ones. All mpfi ones are all the same.
They look like rivets but there regular screws, what you have to do is dremel, or somhow grind a slit in the rivit looking head and take it off with a flat head screw driver.
No there not one way screws, there actual screws, you just need to make a slit for a flat head screw driver, this was honda way of making money when you need a new tps, they would give you a whole new throttle body.
stackz
Oct 4, 2006 07:06 AM
