throotle postion sensor questions!
Old Sep 10, 2008 | 01:41 PM
eghonda1320's Avatar
Default throotle postion sensor questions!
ok i got a jdm b16a full swap from hmotorsonline.com and when i got it the tps wasnt bolted on.now i know how to check the ohms and the voltage and everything for the tps sensor but it seems like the tps sensor will not work cause the little groove that is in the throotle body that the tps bolts on to is on the opposite side to where the little nipple is on the tps. so now i went on ebay to see if they gave me the wrong tps but when i see pics for tps for jdm b16's the tps are the same as mine...what should i do???
Old Sep 10, 2008 | 01:42 PM
Default Re: throotle postion sensor questions! (eghonda1320)
Old Sep 10, 2008 | 02:54 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
The sensor you have should be the right one..
The one on the right is for MPFI..
It should mount as shown:
Old Sep 10, 2008 | 07:37 PM
Marcos Barrios's Avatar
I dont mean to thread jack but how did you even get your tps off dude?
Old Sep 10, 2008 | 11:12 PM
traxxasx's Avatar
Default Re: (Marcos Barrios)
They all come off, if yours look like reivets, grind a slit in them and screw them off with a flat head, there all screws.
Jdm ones have actualy screws you use a allen key to take em off.
Ok, just rotate the tps till it latches inside them bolt it down.
Make sure your not trying to bolt it the wrong way.
If you standing in front of the engine and tps plug should be pointing towars the passenger side.
Old Sep 12, 2008 | 03:30 PM
oh well alright dude thanks for the info
cryingsuns
Mar 20, 2011 01:13 PM
sierrahiker8
Mar 20, 2008 03:25 PM
EFRue57
Sep 17, 2005 05:41 PM
ActiveAero
Aug 15, 2003 07:40 PM
