Lots of parts (TiAL, HP Racing, Full Race, ENDYN, Golden Eagle and More)
Old Sep 10, 2008 | 10:47 AM
alpha's Avatar
Default Lots of parts (TiAL, HP Racing, Full Race, ENDYN, Golden Eagle and More)
These prices do not include shipping. All prices are or best offer
* HP Racing intake manifold for GSR (BRAND NEW - $250.00)
* TiAL 44mm thermal coated wastegate with 5.8lb SMALL GREEN spring (USED - MISSING FIRE RING AND VBAND CLAMPS - $215.00)
* Full Race T4 2JZ-GE exhaust manifold (BRAND NEW - $2,000)
* Flex dump tube with TiAL 44mm flange (USED - $30.00 or $40.00 WITH THERMAL WRAP BELOW)
* Thermal wrap; lots (USED - $20.00)
* K&N RU-4990 3" round air filter (USED - $25.00)
* Stainless steel -3 oil feed lines with inline oil filter (USED - $50.00)
* Stainless steel -8 return line with AN fittings, flange and heat blanket (USED - $50.00)
* Honda OEM B series spark plug wires (USED 1000 MILES - $70.00)
* Hondata thermal intake manifold gasket (USED - $30.00)
* Honda OEM B series throttle body with tps (USED - $30.00)
* Turbo water line fittings (USED - $20.00)
* Honda OEM B series fuel rail from 2000 Si (USED - $30.00)
* Aftermarket larger bore B series fuel rail (BRAND NEW - $70.00)
* ENDYN catch can with valve drain on bottom (USED - $80.00)
* Honda OEM PR4 pistons and rods from 2000 LS (USED 35,000 MILES - $80.00)
* Golden Eagle Mfg. VTEC conversion kit WITH std bore head gasket (BRAND NEW - $185.00)
* Two (2) -16 weld-on bungs (BRAND NEW - $12.00/EACH)
* Honda OEM non-vtec LS rocker arms. LS guys dont sleep on this. Very overlooked when going to larger cams and when a couple sets of different cams have been in the head (USED 500 MILES - $250.00)
Old Sep 22, 2008 | 06:17 AM
alpha's Avatar
Default Re: Lots of parts (alpha)
Old Sep 23, 2008 | 07:01 AM
LS-VTEC-TURBO-EF9's Avatar
PM'D.
Old Sep 24, 2008 | 05:36 AM
alpha's Avatar
Default Re: Lots of parts (LS-VTEC-TURBO-EF9)
Replied to all pm's
alpha
Oct 9, 2008 12:06 PM
alpha
Aug 13, 2008 04:22 PM
acurar0ss
Jun 28, 2005 01:44 PM
