replacing rings in OEM rebuild
Old Sep 10, 2008 | 07:43 AM
SPOOLINmatt's Avatar
Default replacing rings in OEM rebuild
are the rings from honda pre-gapped for b16a blocks that are rebuilt to oem specs?
Old Sep 10, 2008 | 10:11 AM
Dartanian's Avatar
Default Re: replacing rings in OEM rebuild (SPOOLINmatt)
No, you have to check the gaps and file off a bit.
Old Sep 10, 2008 | 12:08 PM
IN VTEC's Avatar
They are supposed to be, but at the least, you should check them.
If your bore is even a little bit too big (above the spec), the rings may not come into spec, even if you have the correct rings.
For example, the piston-to-cylinder wall clearance spec is .0006" to .0016". My clearance is .0020", to allow extra clearance without slap. My ring clearances came in slightly out of spec above the tolerance, which is just fine. The other option would have been to buy a set of aftermarket rings and manually set the clearances.
Modified by IN VTEC at 3:17 PM 9/10/2008
Old Sep 10, 2008 | 04:08 PM
Default Re: replacing rings in OEM rebuild (IN VTEC)
well its stock bore, and its the first time its been honed and it was just a light hone to achieve a nice surface. Im not new to engine building but ive never done an "oem rebuild". So basically it could come out slightly larger gapped than oem? Oh well i guess ill just see when i go to assemble the stuff.
Blake St.romain
Aug 26, 2018 08:34 PM
jetpilot
10
Apr 28, 2005 09:22 PM
PHiZ
Jun 9, 2004 06:01 PM
sander
Mar 29, 2004 09:45 AM
