GSR TRANSMISSION REBUILT HELP
i've heard good things about these guys http://www.gearspeedinc.com/products.htm
synchros are located towards the middle of the page.
If it's been grinding for a while, then you'll need more than just a set of synchro rings. I recommend replacing the 1-2 synchro set (hub, sleeve, rings, springs).
Reverse gear is fine as long as the teeth are straight and don't have any burrs. Rounding off at the tip where it engages the 1-2 synchro sleeve and mainshaft is normal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">If it's been grinding for a while, then you'll need more than just a set of synchro rings. I recommend replacing the 1-2 synchro set (hub, sleeve, rings, springs).
Reverse gear is fine as long as the teeth are straight and don't have any burrs. Rounding off at the tip where it engages the 1-2 synchro sleeve and mainshaft is normal.</TD></TR></TABLE>
ohh my mechanic told me that i had to replace the synchro. he told me just to buy the synchro kit. but i dont no where to get it. im looking around. any shop you guys know other than the dealer?
http://www.hondaautomotivepart...HC%29
Item 007: 23521-P21-315 SLEEVE SET, SYNCHRONIZER (1-2)
This is about as good as the pricing gets.
You also need to purchase:
Item 011: 90202-PH8-000 NUT, HEX. (23MM)
Buy bearings too since you already have to make a big purchase.
Item 013: 91003-P21-003 BEARING, BALL (25X52X14/15) (NTN)
Item 007: 91002-PS1-003 BEARING, BALL (28X60X15)
Item 010: 91216-PH8-005 OIL SEAL (28X41X7) (NOK)
23521p21315, 28x41x7, acura, gsr, item, rebuild, rebuilt, ring, rod, seal, set, socal, synchronizer, syncro, transmission
