Just started a welding class, pics of my first work..
Old Sep 9, 2008 | 12:01 PM
m3bluegsr's Avatar
Default Just started a welding class, pics of my first work..
Here is a pic of my first work that I've done. I figured I would post up some pics of my progress in the class. To give you an idea how new I am to this, we were practicing lighting and adjusting the torches yesterday... Anyways on with the pic of Day 1.
Details: Oxy/Ace - no filler, just practicing pushing puddles, # 2 tip, 1/8th inch mild steel. I started at the top, did ok, then got worse. lol I think i started to do circles, but now i know you should only do C's Anyways feel free to comment or give advice.
Old Sep 9, 2008 | 12:15 PM
randomae's Avatar
Default Re: Just started a welding class, pics of my first work.. (m3bluegsr)
thats pretty cool. i welded for a while in my autobody class but haven't done to much with it. Just a little bit of exhaust work. I started the same way and you will get good pretty quick. good work so far.
Old Sep 9, 2008 | 01:21 PM
k24em2's Avatar
Default Re: Just started a welding class, pics of my first work.. (randomae)
Good job taking a class...It's nice to have an instructor that can stand there and watch you weld and give you feedback right away.
Old Sep 9, 2008 | 02:21 PM
punkinbeck's Avatar
i'm surprised they didn't give you any filler to use. You'll like it a lot more with filler.. The silicone in the filler will help clean the metal and it won't crack.. Have fun with it
Old Sep 9, 2008 | 04:40 PM
fourthgenhatchB17's Avatar
Default Re: Just started a welding class, pics of my first work.. (punkinbeck)
Your work piece probably got pretty hot which is why the bottom got worse, as u said.
Old Sep 9, 2008 | 04:58 PM
m3bluegsr's Avatar
Default Re: Just started a welding class, pics of my first work.. (fourthgenhatchB17)
we didn't use filler on the first day cause the teacher wanted us to get used to melting the metal. We
are practicing filler in the next class. I think it got too hot cause I might not have had the torch at enough of an angle. Cause I dipped it in water after each pass.
Old Sep 9, 2008 | 06:36 PM
coll9947's Avatar
actually looks better than my first day with oxy welding. your instructor has a good idea with having your class just practice melting the metal and pushing the puddle, adding the filler to the equation right away can be overwhelming for some students.
dipping mild steel in water while still extremely hot speeds the cooling process and causes a crystalline structure in the metal called martensite (sp?) to form, which is not what you want if you're going for strength. on test plates like what you're doing it's fine to dip it in water, and i'm sure you'll learn a lot more about steel's crystalline structures and how heat input, preheating, and post heating affect those structures in your class.
whatever you do, don't ever dip a weld in water that you are going to have stress tested for class. put it on a concrete floor and let it cool naturally.
Old Sep 10, 2008 | 06:02 AM
m3bluegsr's Avatar
Default Re: Just started a welding class, pics of my first work.. (coll9947)
Ya we touched on that in my material tech class.. isnt it called quenching or something? The only thing im going to have to get used to is, I like to look pretty close to what im working on... so the heat given off from the metal felt like I was getting a sun tan. Tommorrow we are practicing filler, so ill post some pics of that when im finished.
Old Sep 10, 2008 | 11:03 AM
dh's Avatar
dh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m3bluegsr &raquo;</TD></TR><TR><TD CLASS="quote">Ya we touched on that in my material tech class.. isnt it called quenching or something? The only thing im going to have to get used to is, I like to look pretty close to what im working on... so the heat given off from the metal felt like I was getting a sun tan. Tommorrow we are practicing filler, so ill post some pics of that when im finished. </TD></TR></TABLE>
Quenching is just dipping metal into the water in the quench tank.
Over time, you'll get more and more comfortable welding without getting real close. I did that too when I first learned oxy/ace welding. You want to break that habit especially if you're going to be welding in the overhead position.
Oxy/Ace welding is fun
Old Sep 11, 2008 | 08:09 AM
m3bluegsr's Avatar
Default Re: Just started a welding class, pics of my first work.. (idh!)
Day 2
Details are the same as Day 1, no filler yet.
Old Sep 14, 2008 | 02:23 PM
craphatch's Avatar
turn ur amps down 10 your way to hot from the get go i did the welding calsses all threw high school and collage and i build tanks ant refinery's but other than that its not to bad.. better then some most people ive worked with
Old Sep 14, 2008 | 04:28 PM
k24em2's Avatar
Default Re: Just started a welding class, pics of my first work.. (craphatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by craphatch &raquo;</TD></TR><TR><TD CLASS="quote">turn ur amps down 10 your way to hot from the get go i did the welding calsses all threw high school and collage and i build tanks ant refinery's but other than that its not to bad.. better then some most people ive worked with </TD></TR></TABLE>
He's using a torch.
Old Sep 15, 2008 | 10:12 AM
craphatch's Avatar
Default Re: Just started a welding class, pics of my first work.. (k24em2)
oh i c then thats my bad lol.. i looked like really hot 7018 ok your doing good just try to keep it cooler and youll do fine
Old Sep 15, 2008 | 06:14 PM
crazybeanery0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by craphatch &raquo;</TD></TR><TR><TD CLASS="quote">oh i c then thats my bad lol.. i looked like really hot 7018 ok your doing good just try to keep it cooler and youll do fine </TD></TR></TABLE>
I'm sorry to say but if you thought this was stick welding... you are obviously not a welder...
Old Sep 16, 2008 | 11:12 AM
craphatch's Avatar
Default Re: Just started a welding class, pics of my first work.. (crazy[racial pejorative]y0)
like i said my bad i wasnt paying and attention to what he said he was welding with.... but like i said last time it looks good just keep thing more on the cool side
Old Sep 18, 2008 | 12:51 AM
95delsolz6's Avatar
If it was stick welding and it was that flat, the bead would look really jagged because there would be so much heat and your travel speed would be really fast.
I think the point of using no filler is to get your speed down and to find a good distance away from the work piece. Looks good.
Old Sep 18, 2008 | 10:37 AM
E-Rok's Avatar
EPIC TUNING
Default Re: Just started a welding class, pics of my first work.. (95delsolz6)
wierd, the first thing we did in class is stick weld. doing some oxy cutting tomorrow but we dont weld with it at all.
90HFCrX
Jan 22, 2009 09:59 AM
XXXRacing
Nov 21, 2008 07:51 PM
JJ-Built
Jul 14, 2006 10:52 AM
m R g S r
Aug 23, 2005 06:05 PM
Dreamworx
Jun 6, 2004 11:36 PM
