Integra suspension
I have a 4dr gsr and I wanted to confirm that these struts go to a itr. I think the front is right but i think the rears require the fork style. I would check my car but i don't have it with me at this time. Thanks
I pretty sure these are the ones i need right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinoy2o9 »</TD></TR><TR><TD CLASS="quote">type r rear lower LCA is all u need. </TD></TR></TABLE>
This man speaks truth.
The fronts are completely compatible. The only thing you need to install the rears is a set of rear LCA's from an ITR (or the Function 7 LCA's for the ITR). The OEM ones aren't that expensive.
From an engineering standpoint the ITR LCA's should be stronger and deal with long term stress better. Of course I've never seen a non-ITR LCA fail from normal circumstances though. Having them might make you seem cooler to uninformed JDM bling ****** though.
miketegra
Jun 26, 2004 08:44 PM
Shark Tank
Feb 16, 2003 05:06 PM
