Bullseye S380
I see lots of mustang and supra guys are using this turbo with great success.Has anyone tried using this turbo on a 4 cylinder engine capacity 2.0l and higher ?
thanks
thanks
The S380/S480 is a VERY large turbocharger that unless the Honda is specifically for drag racing only, is not really at all effective, therefore it is not used on the street. In addition, NHRA rules prohibit the use of any turbocharger larger than 72mm for B-series, and 68mm for K-series.
In order to use that turbocharger on the street, in this case, there is no replacement for displacement. Most of the Honda/Mitsu camp stay about the S372 size.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DUB20VT »</TD></TR><TR><TD CLASS="quote">I see lots of mustang and supra guys are using this turbo with great success.Has anyone tried using this turbo on a 4 cylinder engine capacity 2.0l and higher ?
thanks
Not yet
thanks
Not yet
Its for a Drag only VW. I guess the question is compressor wheel inducer size wasn't a limitation, would there be a great advantage using the s380 over the S372 ?
thanks
That is a huge turbo for an inline four 2.X. Tony is a little loco so he may try it. I thought he was going for a 74mm
Largest turbo I have seen or used on a 2.4 liter was an Innovative 76mm. I forget what turbine wheel
thanks
well s380 is very big
and we are 1700m above sea level
VDS has a s380 and let see what
his car does
s372 best bet i have tested it for
south african conditions
you could make 900hp (with good tune)
his car does
The Destroyer
23
Jul 13, 2004 11:16 AM
