95 integra wont start.. searched everywhere, got fuel,and spark ? help
Old Sep 8, 2008 | 06:19 PM
akaplan12's Avatar
Default 95 integra wont start.. searched everywhere, got fuel,and spark ? help
need help!!
95 integra ls 5 speed 100k miles, all of a sudden the car was running at idle for a good 10 mins, then just cut off. no sputter,just cut right off, went to turn it back on ,.cranks but it doesnt start. all grounds are good. along with fuses.
i hear the fuel rail prime, got spark at the spark plug side of the plug wire.
cranks..doesnt start but all accessories come on. no check engine light. using th eobd1 p75 stock ecu. i changes the ignition module, still the same symtoms.
NEED HELP!!
Old Sep 8, 2008 | 06:42 PM
PaulMc's Avatar
Painfully Stupid
Default Re: 95 integra wont start.. searched everywhere, got fuel,and spark ? help (akaplan12)
Change the rotor in the distributer. These kind of issues always seem to be linked to something going bad in the distributer.
Old Sep 8, 2008 | 06:55 PM
akaplan12's Avatar
Default Re: 95 integra wont start.. searched everywhere, got fuel,and spark ? help (-PaulMc-)
ok i will try that.thanks
Old Sep 8, 2008 | 07:08 PM
PaulMc's Avatar
Painfully Stupid
bump.
Good luck.
Old Sep 8, 2008 | 07:22 PM
bankhead83's Avatar
check your coil in the distributor the same thing happen to my car a couple days ago, had to change it is a easy 60 dollar fix, i mean if thats the issue, or your main relax
Old Sep 8, 2008 | 07:29 PM
akaplan12's Avatar
Default Re: (bankhead83)
would i still hear the fuel rail prime if its the main relay? im goin to get a new coil tomarrow.
Old Sep 8, 2008 | 08:28 PM
sg's Avatar
sg
Default Re: (akaplan12)
if u have fuel and spark, check your timing.
that means belt itself. and the timing. good luck
Old Sep 9, 2008 | 04:56 AM
akaplan12's Avatar
Default Re: (sg)
thanks for the help
Old Sep 9, 2008 | 05:04 AM
akaplan12's Avatar
whats the best way to check the main relay?
Old Sep 9, 2008 | 08:33 AM
akaplan12's Avatar
changed cap and rotor, no difference., can it be the main relay even though acc. are working? and fuel rail primes.?
Old Sep 9, 2008 | 12:14 PM
PaulMc's Avatar
Painfully Stupid
If the fuel pump primes then it shouldn't be the main relay.
Old Sep 9, 2008 | 01:28 PM
BoSox46GSr's Avatar
Default Re: (-PaulMc-)
It's the fuel pump that primes, not the fuel rail. It should be a quiet buzzing sound coming from the back seat. If you hear that, then it's not your relay. I bet it's something in your dizzy.
Old Sep 9, 2008 | 03:01 PM
akaplan12's Avatar
Default Re: (BoSox46GSr)
changed the icm, got new plugs and wires, changed the cap/rotor, still just cranks , doesnt fire, ...
Old Sep 9, 2008 | 05:59 PM
CTRwannaB's Avatar
Check compression?
Timing?
Old Sep 9, 2008 | 06:25 PM
akaplan12's Avatar
Default Re: (CTRwannaB)
dist. timing looks good, timing belt is in tact., i will check the compression
Old Sep 10, 2008 | 03:57 AM
akaplan12's Avatar
any more possiblities?
Old Sep 10, 2008 | 05:21 AM
qazaq's Avatar
do u have any gas in ur tank?
take the spark plug out u should have gas in cylinders, after cranking that much u should have plenty of gas there. and as u say u get spark then it should fire
if no fuel check fuses, check power to the fuel pump with a volt meter, check power to injectors (for ur observations they should be fine but double check)
Old Sep 10, 2008 | 05:41 AM
akaplan12's Avatar
Default Re: 95 integra wont start.. searched everywhere, got fuel,and spark ? help (qazaq)
i will check all the 12v sorces and fuses today, along with a compression test once i get the tester.
Old Sep 10, 2008 | 09:50 AM
ozzyman's Avatar
Check your fuel pressure at the rail. Do you even have any gas in the car? Maybe your gauge isnt reading correctly. Are you positive that you have spark? Pull out a spark plug wire, point it really close to a bolt and have a friend crank while you check for spark. If thats okay, then make sure 100% you have fuel in the car and have about 40 psi at the fuel rail.
Old Sep 10, 2008 | 09:56 AM
steveharrmr23's Avatar
Default Re: 95 integra wont start.. searched everywhere, got fuel,and spark ? help (ozzyman)
it is your timing plane and simple it is not right check you cap and rotor make sure it is all good after that check you timing belt cause for some reason you jumpin time
Old Sep 10, 2008 | 03:45 PM
elmejor's Avatar
youre engine code by the way even if cel light doesnt show is 15.The problem you have is ignition output signal.Ihad the same problem car runs but now i cannot redline.
Old Sep 10, 2008 | 03:46 PM
elmejor's Avatar
Default Re: 95 integra wont start.. searched everywhere, got fuel,and spark ? help (elmejor)
try holding the key for 5 seconds.I changed my spark plugs and wires.See if all chambers are good pull one out at a time when trying to start.
Old Sep 10, 2008 | 05:38 PM
akaplan12's Avatar
got and new plugs and wires, im goin to try a new coil and rotor /cap tomarrow am.. i have just under 1/2 tank of gas
Old Sep 10, 2008 | 06:02 PM
LSracing94's Avatar
you got fuel and spark eh? how about timing?
Old Sep 10, 2008 | 06:21 PM
nemesis25's Avatar
Pull the main relay, also double check the ECU and if you did a swap recently check the your connectors. Make sure the sparkplug wires are on correctly.
