Honda Del Sol 93 Problem...
Old Sep 8, 2008 | 06:04 PM
LexKejas's Avatar
Default Honda Del Sol 93 Problem...
Ok so they tried to steal my car last night and now the car wont start... I belive they did something to keep the car from starting to come get it later. So far I have no clue whats wrong... The car sounds like it will start but it wont. My Dad said that maybe it was something with the Distributor but we are stumped... The car will simply not start. Please help! It's urgent! I have no money to take it to a mech at the moment so I hope some one can give me a hint as to whats wrong... they had to have done something that didint take to much effort but I have no clue where to start looking.
Old Sep 8, 2008 | 06:27 PM
LexKejas's Avatar
Default Re: Honda Del Sol 93 Problem... (LexKejas)
Update: There is no spark in the spark plug~
Old Sep 8, 2008 | 06:53 PM
widebodyeg's Avatar
does it just keep cranking but wont start,did they break the ignition and mess with the white plug that goes to the ignition,if they did then they probably broke that white plug and also did u check all the fuses maybe the took some out or some off them burnt out
Old Sep 8, 2008 | 06:54 PM
widebodyeg's Avatar
the coil might be bad in the dizzy or it could be a fuse or something with the ecu
vtecb18c's Avatar
do you happen to have an alarm that might have been tampered with?? if you have no spark than your ignitor might have went bad in the dizzy...or even the coil possibly....did they get under the hood or your not sure?
Old Sep 8, 2008 | 07:01 PM
LexKejas's Avatar
Yeah it keeps craking and wont start.... They took the stero so I'm guessing maybe it was something to do with the wiring... Also I have no alarm in the car since I juuuuuust got it. And I belive they MIGHT have gotten under the hood since the hood was open but Since I arrived at 2 am last night It might have been me... I'm not really sure.
Thank you for your help keep it coming? :D
Old Sep 8, 2008 | 07:04 PM
LexKejas's Avatar
Default Re: Honda Del Sol 93 Problem... (widebodyeg)
BTW Where would I find the "White Plug" I'm not sure what that is.
Old Sep 8, 2008 | 07:14 PM
widebodyeg's Avatar
its the plug that is bolted on the ignition with 2 little screws,on the steering column,and if they messed with some wiring they could have burnt out the coil in the dizzy,if u have a friend with a civic or del sol use his dizzy to see if ur car starts
Old Sep 8, 2008 | 09:15 PM
LexKejas's Avatar
is there any one that can give me a fiting order for the dizzy cables on a honda del sol 93? I think I might have them wrong.
Old Sep 9, 2008 | 07:45 AM
widebodyeg's Avatar
the firing order is 1,3,4,2
Old Sep 9, 2008 | 08:16 AM
MonkeyMagic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LexKejas &raquo;</TD></TR><TR><TD CLASS="quote">Update: There is no spark in the spark plug~</TD></TR></TABLE>
made me lol when i read it
OP let us know if anything else pops up
Robert Watson
Aug 9, 2017 09:23 PM
Camaxx05
16
Jan 2, 2009 03:07 PM
project civic
Mar 10, 2005 08:35 AM
