'76 CB550 No Spark
I'm looking into buying a 1976 CB550 from a guy close by. "It was running when parked 5 years ago" you know the story. Anyway, after looking the bike over and questioning the guy a bunch about it, I find out that he's done a little bit of work to the kill switch on the right handlebar, so I crack it open and take a look. The wiring is kinda jacked up in there. Twisting and some poor soldering.
Black to black, big yellow to little green, red to red, and a small yellow wire that's not connected to anything.
I tried connecting it a few places but still couldn't get spark. What's the wiring supposed to look like under there? Is there a quick way to bypass it all so I don't have to mess with it? In case this isn't the problem, what other places should I check in order to get spark? Everything else looks pretty good on the bike, so I'm hoping once the spark issue is solved, it won't need much more than a tuneup.
In advance, thank you for your responses,
-Chad
-Chad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chadheins »</TD></TR><TR><TD CLASS="quote">Is there a quick way to bypass it all so I don't have to mess with it?</TD></TR></TABLE>
Yeah, +12V straight to the ignition coils under the fuel tank (black/white wire). Just run a wire from the battery.
If its been sitting... it will need a carb rebuild too, and possibly a fuel tank cleaning.
Solved the problem, I opened up the kill switch, the red part and it was all busted up inside. Soldered up the Black and Black/white wires and it runs like a top now. Anyone know how quick these bikes are supposed to be? It feels a little sluggish compared to my CB200T. Doesn't seem right...
sorry to spam your thread, but i noticed you're in champaign. surf on over to http://www.ridingillini.com - it's a local forum
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chadheins »</TD></TR><TR><TD CLASS="quote">It feels a little sluggish compared to my CB200T. Doesn't seem right...</TD></TR></TABLE>
Carbs, ignition, etc... lots of things can be wrong or out of adjustment on an older bike. Go through all of it.
