oil leak in airbox
Old Sep 8, 2008 | 04:13 PM
Cheetah51's Avatar
New User
Default oil leak in airbox
My wife's 1991 Civic is leaking oil through the air filter box. What may be causing this and what can I do to fix it? It has a 1.5L and is fuel injected.
Thanks, Rick
Old Sep 8, 2008 | 05:07 PM
zrickety's Avatar
Default Re: oil leak in airbox (Cheetah51)
pcv system...oil is coming in the hose attached to the intake. try a new pcv valve, you may have to build a catch can if you have excessive blow by
Old Sep 8, 2008 | 05:27 PM
IntegraLova's Avatar
Default Re: oil leak in airbox (zrickety)
You should also go ahead and replace the hose that goes to the pcv valve. Aside from my pcv valve being completley clogged, the hose had collapsed in on itself.After changing those out, my oil consumption has reduced quite a bit. Good luck.
jvr
Mar 14, 2014 11:23 AM
darkcivic90
16
Dec 18, 2011 11:53 PM
SkoundrelUSA
15
Oct 31, 2006 06:27 PM
SkoundrelUSA
Oct 15, 2006 02:29 PM
se93
Dec 27, 2001 06:11 AM
