97 GSR Stalled and now won't start
K soooo I literally just got home from a 500 mile trip in my integra with no problems....I pick my friend up to grab some beer to watch the browns lose terribly yesterday....My driveway is kinda steep and I went to go pull up it and I ran over a bottle so I backed up a little bit...I go to pull around the bottle and It felt like I stalled the car so I pushed the clutch in and the car was still trying to run but it felt like on one cylinder and eventually just died.....I pushed the car in the driveway and let it sit for about an hour.....and went to go and try to start it and nothing.....I pulled the plug wires and stuck a screw driver in there and held it to the block and I get no spark...bad coil maybe??? any ideas?
Thanks in advance!
Steve
Thanks in advance!
Steve
bad coil or ignitor..your def gettin fuel right?? double check your main relay to make sure its not blown
edit: i just read your post and it may be either a wiring issue ot an ecu issue...did you run the ecu for codes??
I got 2 other coils to try from a friend.....ill keep you posted...It's not throwing any lights when the key is just set to on....but don't you have to jump the ecu or something to see all the codes?
NemesisVette
49
Jan 3, 2013 12:37 PM
Milano_EH3
Oct 5, 2006 04:30 PM
tominos
18
Feb 9, 2004 07:23 PM
