FS: GSR crank, P30 pistons on GSR rods w/ARP rod bolts, resurfaced p30 flywheel
Old Sep 7, 2008 | 07:07 PM
Project_EK's Avatar
Default FS: GSR crank, P30 pistons on GSR rods w/ARP rod bolts, resurfaced p30 flywheel
What up,
The GSR crank is out of a USDM B18c1 w/ about 70k miles, never had any spun bearings or had any problems! was taken out because i built the motor..$100
JDM P30 pistons/rings (STD 81mm bore) on GSR rods w/ARP rod bolts (honestly only about 5k miles on pistons/rings!! rings are DEF still good!!! *i made 214WHP on these, have dyno sheet to prove* sale pending on pistons! make offer on rods/arp bolts
^^best OEM piston^^
Fresh out of the machine shop resurfaced p30 flywheel (no miles since machining) also has brand new OEM pilot bearing. $60
will ship everything at buyers expense besides crank (too heavy)
located in jersey
Modified by Project_EK at 8:26 PM 9/7/2008
Modified by Project_EK at 7:22 PM 9/9/2008
Old Sep 7, 2008 | 07:18 PM
ITR.#1446's Avatar
Default Re: FS: GSR crank, P30 pistons on GSR rods w/ARP rod bolts, resurfaced p30 flywheel (Project_EK)
pics not working
Old Sep 7, 2008 | 07:26 PM
Project_EK's Avatar
fixed thanx
dc2JDMwhore
May 12, 2014 02:57 PM
jspec-integ Ls
Northwest (Sales)
Jun 1, 2008 11:06 PM
