Added too much hardener to my paint, curious of the effects.
Old Sep 7, 2008 | 06:04 PM
O16581724 5 2 5's Avatar
Default Added too much hardener to my paint, curious of the effects.
I couldn't find much reading. My buddy was rushing me along to paint my car and my mixing cup had percentages i couldn't figure out instead of ratios (like fill the 8 column to 6, fill the 1 column to 6, fill the 2 column to 6, i understand that). He said "Here, go by this" and there were numbers up the cup going to 10 next to the ounces and said "Fill it to a number, then add 1 for the hardener, and 2 for the reducer". So i filled it to 6, added 1 (7) for hardener, and 2 (9) for reducer. Not realizing i did a 6:1:2 mix until i'd sprayed the car, it needed to be 8:1:2.
I discovered what was wrong on my final coat when i did 4 up 1 and up 2, i then realized how off it was.
Laid pretty smooth though, lol.
Modified by O16581724 5 2 5 at 7:31 PM 9/7/2008
Old Sep 7, 2008 | 07:39 PM
wholios-EG's Avatar
Default Re: Added too much hardener to my paint, curious of the effects. (O16581724 5 2 5)
you should be ok the paint will dry faster but if you laid it on to thick it might start to crack but still need a pro to get it to this
Old Sep 8, 2008 | 05:53 AM
Default Re: Added too much hardener to my paint, curious of the effects. (wholios-EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wholios-EG &raquo;</TD></TR><TR><TD CLASS="quote">you should be ok the paint will dry faster but if you laid it on to thick it might start to crack but still need a pro to get it to this </TD></TR></TABLE>
I did around 3 coats of urethane, should be a bit less resistant to cracking than enamel i hope. It was clear hardener, so it's actually taking forever to dry, might be a good thing though.
Old Sep 9, 2008 | 06:10 PM
Snailor Built's Avatar
tacky for a while was our experience with a similiar incident
Old Sep 9, 2008 | 06:52 PM
Default Re: (30lb_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 30lb_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">tacky for a while was our experience with a similiar incident
Having the same one, it was tacky for close to 3 days and it's still soft on that 3rd day.
Got a few spots i dinged putting it all together while soft, d'oh.
Old Sep 9, 2008 | 09:14 PM
***strangles bart***
kixcrx
Paint and Body
18
Aug 31, 2007 04:31 PM
JamesV
Jun 5, 2006 08:10 PM
theslugbug
Apr 6, 2006 04:45 AM
antiJDM
Oct 25, 2005 04:11 PM
CivicHP
Apr 19, 2005 06:52 PM
