da coilovers on a dc
Old Sep 7, 2008 | 01:50 PM
dapek's Avatar
Default da coilovers on a dc
Just a quick question im sure theres a simple yes or no answer but maybe not I need to know if tein full coilovers from a da will fit on a dc or are the front forks diff. etc? My buddy wants to buy a used set from a guy for a killer deal whom drives a da and doesn't know if they would fit?
Old Sep 7, 2008 | 05:13 PM
dapek's Avatar
Default Re: da coilovers on a dc (dapek)
any one know?
Old Sep 7, 2008 | 07:12 PM
BMXman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dapek &raquo;</TD></TR><TR><TD CLASS="quote">Just a quick question im sure theres a simple yes or no answer but maybe not I need to know if tein full coilovers from a da will fit on a dc or are the front forks diff. etc? My buddy wants to buy a used set from a guy for a killer deal whom drives a da and doesn't know if they would fit? </TD></TR></TABLE>
they will not bolt right in...the shock bodies have different diameters...the DA's are larger
Old Sep 7, 2008 | 07:20 PM
StayKrafty's Avatar
Are you talking about struts and the coilovers? Or just the coilovers?
Old Sep 7, 2008 | 07:32 PM
dirtygsr99's Avatar
wont springs from a da fit a dc but there alittle shorter right? so if u get a 2in drop it will be like a 2.50 or 2.25 drop if im wrong chim in
Old Sep 8, 2008 | 09:48 AM
dapek's Avatar
Default Re: (mybikeisblack)
The struts and coilover sleeves in one (see above: Full Tein Coilovers), It seems like i'd just have to use the DC forks but i could be wrong. My searches came up as only DC to DA not the other way around and on there it said as long as their not from a dc2r chassis then they would only need dc front forks to work on a da so i figure that if you just reversed that then they would still work on a DC. I have no clue if this assumption is correct so let me know?
Old Sep 10, 2008 | 07:55 PM
BMXman's Avatar
Default Re: (dapek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dapek &raquo;</TD></TR><TR><TD CLASS="quote">The struts and coilover sleeves in one (see above: Full Tein Coilovers), It seems like i'd just have to use the DC forks but i could be wrong. My searches came up as only DC to DA not the other way around and on there it said as long as their not from a dc2r chassis then they would only need dc front forks to work on a da so i figure that if you just reversed that then they would still work on a DC. I have no clue if this assumption is correct so let me know? </TD></TR></TABLE>
yeah it will work if you use dc front forks but there is a good chance you will have clearance issues...here's a link that should help out a lot.
http://www.g2ic.com/forums/showthread.php?t=30796&
Old Sep 11, 2008 | 03:57 AM
gtec8285's Avatar
Default Re: (dapek)
they would fit as long as you use the right forks
Old Sep 11, 2008 | 11:07 AM
llozll's Avatar
Default Re: (gtec8285)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtec8285 &raquo;</TD></TR><TR><TD CLASS="quote">they would fit as long as you use the right forks</TD></TR></TABLE>
+1
i've installed koni yellow for da to my dc with da forks.
installation was successful
yet my driving is always unsuccessful
cyclotegra
Suspension & Brakes
Jan 29, 2012 08:54 AM
iheartxhonda
Oct 7, 2008 11:01 AM
itsmarcnotmark
Oct 6, 2008 07:00 AM
skyliner186
Mar 28, 2004 02:57 PM
