GSR strut bar question
Old Sep 7, 2008 | 11:02 AM
redlinexd's Avatar
Default GSR strut bar question
will the gsr strut bar fit with the dc sport one?
Old Sep 7, 2008 | 11:07 AM
lv6l's Avatar
Do you mean is the GSR strut bar fitment same as this DC strut.
If so, no. The GSR strut bolts onto the frame of the car above and further out from the shocks.
Old Sep 7, 2008 | 11:11 AM
shortstopNE's Avatar
Default Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l &raquo;</TD></TR><TR><TD CLASS="quote">Do you mean is the GSR strut bar fitment same as this DC strut.
If so, no. The GSR strut bolts onto the frame of the car above and further out from the shocks. </TD></TR></TABLE>
What he said. Let me know if you sell the DC
Old Sep 7, 2008 | 11:16 AM
redlinexd's Avatar
well what i mean is like will the gsr bar fit on to the frame w/o touching the dc sport strut bar? sorry for not being specific
Old Sep 7, 2008 | 11:20 AM
lv6l's Avatar
Oh, hmm that is a tough question to answer from just looking at the picture. It would be very close. They will probably get in the way of each other since it looks like both of the bar's height is about equally the same. This I am unsure, give it a try and post up some pictures Good luck.
Old Sep 7, 2008 | 11:29 AM
redlinexd's Avatar
lol well someone is selling a gsr bar on craigslist for 20 bucks, if it doesnt fit i guess its not that bad. at least i can resell it
Old Sep 7, 2008 | 11:30 AM
redlinexd's Avatar
o wait another question, do i need like any bolts or anything to install the GSR bar?
Old Sep 7, 2008 | 11:44 AM
BlueIntegraBoy's Avatar
Default Re: (redlinexd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinexd &raquo;</TD></TR><TR><TD CLASS="quote">o wait another question, do i need like any bolts or anything to install the GSR bar?</TD></TR></TABLE>
Yes, since you don't have the studs on the strut tower like the GSR does, you will need to pick up nuts and bolts.
Old Sep 7, 2008 | 11:49 AM
lv6l's Avatar
Yep, you need studs. I didn't have any, what I did was drilled two holes on each side and use bolts and nuts that I picked up from a local hardware store. Works great.
Old Sep 7, 2008 | 12:22 PM
redlinexd's Avatar
i have to drill 2 holes on the frame? dang...
Old Sep 7, 2008 | 12:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinexd &raquo;</TD></TR><TR><TD CLASS="quote">i have to drill 2 holes on the frame? dang... </TD></TR></TABLE>
Yeah, doesn't look like you have the rubber plugs. But there should be two indentations on each strut tower to let you know where to drill.
Old Sep 7, 2008 | 12:37 PM
redlinexd's Avatar
Default Re: (BlueIntegraBoy)
are you talking about that black rubber thing near the bolt under near the dc bracket?
Old Sep 7, 2008 | 01:04 PM
redlinexd's Avatar
bump
Old Sep 7, 2008 | 01:30 PM
jvillagran2000's Avatar
is that the OEM resonator air box?why havent you taken it off it's dead weight.why do you want 2 strut tower bars?use the one that is the lightest and get done with it.
Old Sep 7, 2008 | 07:58 PM
lv6l's Avatar
The picture you posted up about the rubber plug looking thing is not the hole where you should drill.
If you are standing in front of you motor looking straight into the cabin. Look at your shock stud on your driver side, to the right of that you will see empty space on your red frame; it's kind of elevating slope upwards. If you hit your clip for your windshield hose you've gone too far. I guess I would say it's between the windshield hose clip and shock stud. There should be two indentation of holes there. Same on the other side. Once you buy the GSR strut you can see where it fits.
But why are you putting on two strut bar?? It will not make much difference. Pick and use one.
Old Sep 8, 2008 | 08:44 PM
redlinexd's Avatar
yeah, i decided not to get it, haha
mugenracer
Feb 28, 2002 11:07 AM
