Do I HAVE to use a ring gear hoilder when reinstalling the flywheel?
Old Sep 7, 2008 | 09:48 AM
slayerP's Avatar
Default Do I HAVE to use a ring gear hoilder when reinstalling the flywheel?
I haven't been able to find one in town, and seeing how I'm probably not gonna ever need it again, I don't really wanna order one. Have any of you guys installed the flywheel without using the ring gear holder with out problems? It would be a shame to have take take apart the car again because of excessive vibrations or something like that. The car is in 88 crx with a b16a and ys1 lsd trans.
Old Sep 7, 2008 | 11:11 AM
acmoc's Avatar
Default Re: Do I HAVE to use a ring gear hoilder when reinstalling the flywheel? (slayerP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slayerP &raquo;</TD></TR><TR><TD CLASS="quote">I haven't been able to find one in town, and seeing how I'm probably not gonna ever need it again, I don't really wanna order one. Have any of you guys installed the flywheel without using the ring gear holder with out problems? It would be a shame to have take take apart the car again because of excessive vibrations or something like that. The car is in 88 crx with a b16a and ys1 lsd trans.</TD></TR></TABLE>
I think you do, so it aligns rite. But do not trust me, I have not done my own flywheel yet.
Is the one you need to install the clutch the same
Old Sep 7, 2008 | 12:28 PM
traxxasx's Avatar
i just shoved a chizzle between the case and the flywheel teeth, been 4 months now on my stage 3 6 puck and the car runs smooth.
Old Sep 7, 2008 | 12:35 PM
slayerP's Avatar
Default Re: (traxxasx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by traxxasx &raquo;</TD></TR><TR><TD CLASS="quote">i just shoved a chizzle between the case and the flywheel teeth, been 4 months now on my stage 3 6 puck and the car runs smooth.</TD></TR></TABLE>
That sounds like something I should do then. What's the point of even doing this? Is it just to lock the engine in place, or do u actually need the flywheel completely stationary while you torque down the bolts?
Old Sep 7, 2008 | 02:17 PM
SIred91's Avatar
Rainman
Default Re: (slayerP)
I just used a box wrench and put one end on the flywheel bolt and the other on the dowell pin on the block to hold it while I torqued the bolts into place....
Old Sep 7, 2008 | 02:37 PM
slayerP's Avatar
The flywheel is on and torqued down, thanks for the replies guys.
crxjarred
Transmission & Drivetrain
Jul 12, 2014 01:21 AM
damonk
Nov 26, 2009 12:31 PM
police vehicle tech
21
Nov 15, 2009 08:12 AM
thewrai6th
Nov 3, 2009 06:09 PM
zman
Nov 16, 2005 04:37 AM
