POwer steering help!!!!!!!
I put a F20B into my 2001 accord and for those of u who know what i'm talking about i worked out most of the problems......but now i'm trying to get some of the luxuries worked out. My power steering the bracket from the f23 (stocky motor) doesnt work and i dont even have a pump.....plus i have to make my own line i think......i dont even know can saomeone help me with this issue???
i heard rumors of being able to use a line (the feed line) from an earlier model accord..........is that true????
what pump and bracket can i use???
need help asap......my arms are getting tired of moving this big *** boat around........
thanks for ur time
thanks for ur time
as for the bracket.. use an f20b bracket and pump. f20b is a jdm accord motor right? i couldnt immagine having to use a different line.. or just go to autozone, get a matching size hose, put them together (id throw silicone gasket sealer around them just incase) and there ya go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jbur074 »</TD></TR><TR><TD CLASS="quote">as for the bracket.. use an f20b bracket and pump. f20b is a jdm accord motor right? i couldnt immagine having to use a different line.. or just go to autozone, get a matching size hose, put them together (id throw silicone gasket sealer around them just incase) and there ya go. </TD></TR></TABLE>
I dunno about that one, my guess would be a 98+ Prelude model H22 bracket, much like it is for the H22A swap on the cars.
If the Accord one bolts up but doesn't fit (which is correct) then the H22 98+ bracket should do the trick
got the bracket......now the pump i heard i could use one from another year car like a way earlier accord......is that true does any one know.....???????
LsVtakYO
Sep 10, 2011 02:42 AM
not7fifteen
Apr 30, 2002 10:26 AM
