Mixing Manufacturer Wheels
Old Sep 7, 2008 | 04:02 AM
izaguf's Avatar
Default Mixing Manufacturer Wheels
Wondering if the center of 15" Nissan Altima Wheels match the size I need for a 92 Accord. Honda has a 61mm center, but i havent got access to the specs for the 94 Altima wheels.
Any help would be greatly appreciated.
Izaguf
Old Sep 7, 2008 | 04:52 AM
GhostAccord's Avatar
Default Re: Mixing Manufacturer Wheels (izaguf)
Not exactly the same size but they should fit.
Vehicle / Year / Size / Bolt Pattern / Lug Size / CB / OS
ALTIMA / 93-01 / 15 X 6 / 4X114.3 / 12mmX<FONT COLOR="darkred">1.25</FONT> / <FONT COLOR="darkred">66.1</FONT> / +45-40-35
ACCORD / 90-97 / 15 X 6 / 4X114.3 / 12mmX<FONT COLOR="darkred">1.5</FONT> / <FONT COLOR="darkred">64.1</FONT> / +45-40-35
As you can see most of the measurements match up except the center bore (CB) & the lug size. In this particular case the Altima CB is 2mm larger. With that small of a difference there won't be any problems fitting the Altima wheel on your Accord. As for the lug diameter, You may have to bore/drill the lug holes .25mm but I doubt it.
Modified by GhostAccord at 9:58 AM 9/7/2008
Old Sep 7, 2008 | 05:47 AM
02 accord's Avatar
Default Re: Mixing Manufacturer Wheels (GhostAccord)
The lug size is the same (12 mm), just different thread. Should fit just fine.
Old Sep 7, 2008 | 05:56 AM
Default Re: Mixing Manufacturer Wheels (02 accord)
thanks for catching that
88rexdxa6ed
Nov 24, 2003 11:42 PM
Rob Dizzle
Oct 23, 2003 07:35 AM
gribbs
Mar 27, 2003 10:13 AM
civictypenos
Nov 29, 2002 09:38 PM
