Honda S2000 Honda S2000
product review: password jdm intake review
Old Sep 6, 2008 | 09:19 PM
evil vapor's Avatar
Default product review: password jdm intake review
What's up guys, new and old, that remember me from years past. I've been lurking around the boards for the past few years staying busy enjoying life outside the crazy forums. My car is pretty much back to stock form now; mostly sold off the aftermarket parts except for the stack cluster and other minor parts. I'm looking to build up the car again, this time picking up parts for good and having a clear idea of what use I'll want from the car. I've posted this in s2ki.com in case any of you browse both forums.
Right now, the engine is stock. Bolt-ons include lightweight aluminum engine pulleys, hondata intake gasket, denso iridium ik24 plugs, throttle body coolant bypass, greddy catch can, spoon clutch and flywheel. The exhaust system is stock (header, cat, cat-back with gutted ap1 mufflers). The ECU is stock, all stock parts are ap1. The only ap2 part on the car is the rear differential assembly with stock LSD and 4.10 final drive.
I've ran most of the popular intakes since picking up my ap1 from Matt Piercy at Honda World in Westminster in 2001. In order of appearance, I first started off running the spoon snorkel with K&N filter, then Comptech intake, AEM V1 CAI, J's tschunioko chambered snorkel intake, K&N CAI, K&N short ram intake, Mugen V1 intake, and lastly the prototype memory fab chamber intake (minus snorkel) shown in the pictures below. The "filter on a stick" intakes were the loudest and showed good gains on the dyno with the typical 4-5krpm intake "dyno hump" resulting from the resonance intake runner length. The only other intake I was able to dyno was the J's intake. I tracked, auto-x'd, and daily drove on all intakes. I'll note the differences with the password jdm intake in the end of this writeup and mention the ups and downs.
Install: The Password JDM intake comes in a complete kit, equipped with hardware and an installation manual. The easiest intake install was the K&N short ram intake and the hardest was the J's tschunioko chambered snorkel intake since it required removal of material from the stock hood above the radiator support. The K&N and AEM CAI intakes can be tricky too for the first timers.
The Password JDM intake doesn't require the hood clearance of the Mugen and J's intake. It fits like the Spoon snorkel which makes it nice for people who don't want to cut their hoods. I know some people had fitment issues with the real spoon snorkel and claimed the spoon style (fake/copies) snorkels fit better. I never had any rubbing issues since some adjustment with the hood latch is required. One thing I've learned with the s2000: not every s2000 is exactly the same, even within the same model year (AC line routing that differed between years effected the J's racing Engine damper). My hood is already cut so it's a non-issue with the Password JDM intake. You don't need to cut your hood for the Password JDM intake. If you follow the directions, you wont have any problems. Just make sure you don't bolt anything up tight until you have it all together. It fits like a puzzle with 4 main pieces. If your bolt holes don't line up, don't force them into place as the carbon is thin and it will crack if it is extremely Sasquatch-handled! The panels will flex and give but they'll only flex to a certain point. If you have any doubts about installing this killer intake, take it to a pro that will back up their work in case you have any problems. Did I mention it weighs practically nothing? I think the K&N air filter weighs as more than the whole kit. The intake opening is HUGE. One more thing, you might need to move your hood latch for the hood to catch and close properly otherwise you might damage the intake. Mine was adjusted since running the Mugen and J's intake so again that was a non-issue. The intake install took a total 1hr, I didn't have to remove the front bumper since I'm not running any splash guard or an upper radiator cover which allowed me to snake the snorkel portion between the radiator support and bumper.
Cliff Notes: Follow install manual and don't rush it. Install takes just as long as the J's intake.
Quality: The Password JDM rates on par with the Mugen intake on quality when it comes to carbon with the Mugen having a larger weave pattern and thicker gauge carbon. There are some parts of the Password JDM intake that are thin but very strong, almost similar to the axle carbon front and rear diffusers I had, showing proper engineering resulting in a strong part with the least amount of carbon required: a really light intake. The J's intake used thicker carbon than the Mugen/Password JDM and side by side is dwarfed by the larger chambers of the Password JDM. The engine bay is engulfed in carbon for those who have a fetish with the stuff running the Password JDM intake. Lastly, the aluminum tube intakes were just that, very affordable and they worked but were very loud and throttle response seemed to be sluggish with them but I'll leave that for the drive impressions section. Almost forgot to mention the comptech and spoon snorkel intakes were most stock-like in appearance and performance.
Cliff Notes: Password JDM intake quality is like the Mugen intake (top tier quality).
Street Driving impressions: Quick disclaimer-With any intake, idle is affected slightly, as is throttle response (transient response), and seat of the pants feel. My seat of the pants feel is gauged by how quickly the car rev's through the gears and how quickly you reach a certain speed within a given distance (acceleration). Dyno charts can only be used to compare one mod to another coupled with tuning on the same car on the same dyno on similar conditions. Sure, you can compare one dyno chart to another but I think you'll be wasting you'll time as before and after dyno charts are the best for comparison purpose.
I hope I'll get a chance to dyno this intake as the seat of the pants street driving impressions give me a good feeling about this intake. It works. The exhaust note after install is a little deeper. The intake note isn't as loud as the aluminum tubed intakes (K&N CAI and AEM CAI) but the engine clearly rev's quicker and has a deeper intake and exhaust note. Seat of the pants feel indicates a strong midrange pull and no lag up top. The intake is louder than the J's, Mugen, comptech and spoon but not as loud as the AEM and K&N aluminum CAI. The carbon definitely has a role in silencing the intake note. What I noticed with the J's and Memory Fab intake was a choking effect at high rpm's. The engine simply wants to rev with the Password JDM intake.
Cliff Notes: Engine rev's are quick with the Password JDM with a good pull through the mid range + top end.
Gas Mileage: I'll post an update as I rack more miles on the intake and followup with a long term update.
Track experience: I'll post an updated review after the Sept 14th SDBMWCCA auto-x. Auto-x events are like truncated road course events where you don't spend nearly as much time in full throttle so little differences will show in your auto-x times, especially on a longer course found in the West lot at Qualcomm stadium (1.3+ mile auto-x course).
Update 09/11/08
Pictures: poor picture quality is due to the source, my cell phone!!!
Complete Kit:
Large intake opening
Memory Fab chamber vs Password JDM chamber
Tight squeeze above the radiator support
Large volume snorkel
Nice blurry image
Bumper opening
Picture whoring:
Memory Fab seat:
Chicken strips
More carbon bling:
Also, I forgot to mention if you don't have hood struts, you'll need them since the stock hood prop will need to be removed due to clearance issues with the intake snorkel.
Modified by evil vapor at 3:15 PM 9/11/2008
Old Sep 6, 2008 | 09:30 PM
iam7head's Avatar
Default Re: product review: password jdm intake review (evil vapor)
glad you like it but i seriosly doubt any intake on the market will put a dramatic change on the power output(in near stock trim form)
please post dyno if you happen to be on the roller
Old Sep 7, 2008 | 09:00 AM
evil vapor's Avatar
Default Re: product review: password jdm intake review (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">glad you like it but i seriosly doubt any intake on the market will put a dramatic change on the power output(in near stock trim form)
please post dyno if you happen to be on the roller </TD></TR></TABLE>
I'm a skeptic too. So far, running this intake=the biggest difference versus a tuned AEM ECU and toda header. The car pulls at speed and rev's more happily. Who wants to lend out their dyno?
Old Sep 9, 2008 | 05:04 PM
s2000 mf's Avatar
Great Review I would get this Intake if i was not going FI.
Old Sep 10, 2008 | 06:29 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: product review: password jdm intake review (s2000 mf)
Thanks for taking the time to do this
Old Sep 11, 2008 | 02:15 PM
evil vapor's Avatar
Default Re: product review: password jdm intake review (White Smoke)
updated first post with pictures
Old Sep 12, 2008 | 01:39 PM
jzn_kp61's Avatar
Very helpful indeed!
Old Sep 18, 2008 | 09:20 AM
tanman's Avatar
Thanks for that review. It currently is the best intake on the market for the S2000.
Tan
Old Sep 18, 2008 | 09:30 AM
Black S2K's Avatar
that thing is huge. If i had 900 to spend on an intake this would prolly be my choice. But for now ill stick to my spoon snorkle replica. What i like most about ur password jdm piece is that the scoop is really big compared to other snorkle/ram air type intakes.
Old Sep 18, 2008 | 03:12 PM
ITRbroham's Avatar
shit post warrior
Default Re: (tanman)
Welcome back, Ardy!
Informative review from a knowledgeable guy.
Old Sep 18, 2008 | 05:47 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (ITRbroham)
glad to see you around again..... at least i know im not the only lurker....
Old Sep 18, 2008 | 06:28 PM
honeybadger's Avatar
That is such an extravagant design for the intake piping.
Old Sep 21, 2008 | 06:09 AM
fatality122887's Avatar
after installing this you self would u say this intake would fit with a TB spacer installed? it pushes the TB about an inch forward. if u wouldn't mind looking at all the mount locations and the clearances 2 figure it out 4 me it would be appreciated.
Old Sep 22, 2008 | 11:14 PM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: (honeybadger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honeybadger &raquo;</TD></TR><TR><TD CLASS="quote">That is such an extravagant design for the intake piping. </TD></TR></TABLE>
**points the obvious**
So that's what the S2k's stomach looks like....
Old Sep 23, 2008 | 04:42 PM
sleepycivichb's Avatar
I'm in for updates...
Old Sep 26, 2008 | 01:13 AM
eg6T's Avatar
Default Re: (sleepycivichb)
are the carbon wheels on your bike just for bling? i mean those chicken strips are huuuggeee
Old Sep 28, 2008 | 06:04 AM
Raabjorn's Avatar
Got my intake a few days ago. And I agree with you, the car revs faster. I've hit the rev limiter several times the past days. I rarely did that with my aem intake....
There is also faster response thanks to the big air chamber.
I got it in kevlar, since everybody else is going for cf...
https://honda-tech.com/zero...age=5
Old Oct 5, 2008 | 08:37 PM
delux247's Avatar
Default Re: (Raabjorn)
Great thread!!! I love the Sato Racing Exhaust on your RC51. I used to have that exact same exhaust on my RC although I didn't have those blingin *** wheels .
Old Oct 5, 2008 | 09:58 PM
Driven's Avatar
Default Re: (Black S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black S2K &raquo;</TD></TR><TR><TD CLASS="quote">If i had 900 to spend on an intake</TD></TR></TABLE>
wait...
what? $900 for that? ouch...
Old Oct 6, 2008 | 12:24 PM
Boots's Avatar
Default Re: (Driven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven &raquo;</TD></TR><TR><TD CLASS="quote">
wait...
what? $900 for that? ouch...</TD></TR></TABLE>
actually its more like $1100....i personally think it's way too much for an intake
Old Oct 6, 2008 | 06:59 PM
In-N-Out Burger
Default Re: (boots)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boots &raquo;</TD></TR><TR><TD CLASS="quote">
actually its more like $1100....i personally think it's way too much for an intake</TD></TR></TABLE>
Seriously...I'd rather put that money into a turbo setup!
Everyone knows B00st &gt; NA
Old Oct 8, 2008 | 09:34 AM
ku's Avatar
ku
isn't this a j's racing replica?
Old Oct 8, 2008 | 01:22 PM
tanman's Avatar
Default Re: (ku)
Nope, this is an original designed Password JDM part, not a knock off of another design.
Old Oct 8, 2008 | 01:27 PM
CXHATCHver2.2's Avatar
Waiting for dyno #'s before judgement
Old Oct 11, 2008 | 04:13 AM
ku's Avatar
ku
its similar to the j's racing doe?
