Tranny Q for the Tranny Guru...
I have a civic with a D15B8. I also have a Full D16Z6. I plan on rebuilding my D16. When I got my new Car I can tell my old D16 had more to it, but it seems that my B8 tranny is faster at a lower RPM. So the Q is since mt D16 Reved higher, would my B8 tranny go faster that my Z6. Which is better for my build.
D15B8/CX trannys suck, unless you want good mileage. D16Z6/EX/Si tranny is geared much shorter and will make a world of difference for acceleration, CX tranny has theoratically higher top speed, but it will take forever and a day to get there.
so even with an engine that will rev (easier) higher the Z6 is still better. I thought that would be the case. witch is kinda unfortunately because the 3rd gear on my Z6 popped out a lot before I retired it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tei344 »</TD></TR><TR><TD CLASS="quote">so even with an engine that will rev (easier) higher the Z6 is still better.</TD></TR></TABLE>
Yes, some guys will actually swap in a Z6 tranny mated up to a D15B7 for the acceleration
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tei344 »</TD></TR><TR><TD CLASS="quote">I thought that would be the case. witch is kinda unfortunately because the 3rd gear on my Z6 popped out a lot before I retired it.</TD></TR></TABLE>
Pop the Z6 tranny apart and replace the 3rd gear syncro. I've never popped a tranny apart yet, just never had any real reason to, but they're quite simple to work on i'm told.
Z6 tranny is better geared for acceleration than the B8, that's a fact. You may be able to go faster at the same rpm/gear with the B8, but it will take you longer to get to that speed.
My 92 cx runs like a dog, and the gears are so long on it. I had a 91 CRX Si and loved how that car performed compared to this one. I would definitely risk losing some precious mpg for an overall quicker and more enjoyable ride.
well that settles it then. Z6 it is. I taking a MT class at collage, i'm a student at UTI, so I 'll be able to pop that apart and fix it right up in no time. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina »</TD></TR><TR><TD CLASS="quote">Its not the synchro causing it to pop out of gear. </TD></TR></TABLE>
I think your right on this actually. I keep seeing "popping out of gear syncros must be bad" kind of posts, but all I can see bad syncros doing is causing grinding when shifting. I'd be more inclined to think there was a spring/detent type thing bad personally. But I haven't had a chance to take a honda tranny apart yet, I will if one ever goes bad on me.
thanks guys. slow and steady. i'll have it done in a while. i just need a garage to work on it. I live in boston and i can work on cars at my appt. once i get a small ish space to work on i'll be on the go.
AlphaQup
14
Jul 4, 2003 09:28 AM
